running mapserv.exe
Lowell Filak
lfilak at MEDINACO.ORG
Tue Sep 14 08:14:15 EDT 2004
The following message was sent by Jim Burnett <jburnett at E-MASI.COM> on
Mon, 13 Sep 2004 15:26:34 -0700.
> Hey, I need to be able to run mapserv.exe from the command line. Can I
> do this without installing a webserver? Basically I want to use it
from > an application, and not from the web.
> -Jim
Jim;
There are (at least) a couple of options:
1)
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0306/msg00566.html
2) Use MapScript in a scripting language which will allow you to
integrate the MapServer capabilities as a new module.
Lowell
