Mapserver Web service questions
Ed McNierney
ed at TOPOZONE.COM
Wed Sep 15 11:01:57 EDT 2004
Andy -
"Web service" is a pretty loose term; do you have specific interface
constraints (i.e. a particular interface model, etc.)? MapServer
natively supports the OGC Web Map Service (WMS) that provides a very
nice, simple way to make an HTTP GET request that returns a image file
in the requested format. Such a request can be easily used in, for
example, the "src=" property of an <IMG> tag on the requesting page. It
can, of course, also be used in more complex environments where the
client/requester is a different sort of application than a simple HTML
viewer.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of ANDY CANFIELD
Sent: Wednesday, September 15, 2004 10:45 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Mapserver Web service questions
To anyone who may know,
Can Mapserver be used like a web service?
Here is my situation. I have a small device that I want to show maps on.
There are two ways I can do this as the device has a browser I can make
a small web page for it, or to give it more functionality I can write an
embeded app that displays maps from a web service.
So what I need to know is can Mapserver be used like a web service or do
I need to write a web service that acts as the interface to Mapserver?
I am using Mapserver for Windows and currently it's set up with php
Mapscript for my web maps.
If I can use Mapserver as a service can I use the same one I'm running
php Mapscript against?
If not and I write a service is it safe to target the same Mapserver as
php is using via it's Mapscript interface?
If it helps any the device sending the requests will be a Nextel
Blackberry.
The language of the app sitting on the device will be J2ME ( Java Micro
Edition ). The service itself if I have to write one will be in C++.
Any help or suggestions would be greatly appreciated.
Thanks,
Andy
_________________________________________________________________
Don't just search. Find. Check out the new MSN Search!
http://search.msn.click-url.com/go/onm00200636ave/direct/01/
