Mapserver Web service questions
ANDY CANFIELD
andy_canfield at HOTMAIL.COM
Wed Sep 15 15:49:20 EDT 2004
Ed,
Thank you! I'm reading through the docs now and they have everything I was
wanting to know, and kudos to who ever did the docs they are very easy to
use.
Andy
>From: "Ed McNierney" <ed at topozone.com>
>To: "ANDY CANFIELD"
><andy_canfield at HOTMAIL.COM>,<MAPSERVER-USERS at LISTS.UMN.EDU>
>Subject: RE: [UMN_MAPSERVER-USERS] Mapserver Web service questions
>Date: Wed, 15 Sep 2004 12:35:23 -0400
>Andy -
>Please start by reading the WMS Client and Server documentation, which
>you can find at http://mapserver.gis.umn.edu/doc.html - it's very simple
>to use.
> - Ed
>Ed McNierney
>President and Chief Mapmaker
>TopoZone.com / Maps a la carte, Inc.
>73 Princeton Street, Suite 305
>North Chelmsford, MA 01863
>ed at topozone.com
>(978) 251-4242
>-----Original Message-----
>From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
>Behalf Of ANDY CANFIELD
>Sent: Wednesday, September 15, 2004 11:56 AM
>To: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: Re: [UMN_MAPSERVER-USERS] Mapserver Web service questions
>Ed,
>That is essentially what I was looking for.
>So I can send and http request to it via a small device and have it
>return an image directly?
>Or does it put the image in a directory on the server from which I must
>retrieve it via an io stream?
>If I go the web service route it will be a MIDlet on a phone making the
>request then embeding the image on the MIDlet's displayable canvas much
>like ROSA does in Applet context. However ROSA pulls from a link
>essentially to where the image has been created on the server.
>Also in the GET request how do you specify layers off or on etc? Or do
>you have to send a PUT type request first to configure the output that a
>GET will return?
>So far I have only used the php Interface so my knowlege of the actual
>Mapserver itself is weak.
>Thanks,
>Andy
> >From: Ed McNierney <ed at TOPOZONE.COM>
> >Reply-To: Ed McNierney <ed at TOPOZONE.COM>
> >Date: Wed, 15 Sep 2004 11:01:57 -0400
> >Andy -
> >"Web service" is a pretty loose term; do you have specific interface
> >constraints (i.e. a particular interface model, etc.)? MapServer
> >natively supports the OGC Web Map Service (WMS) that provides a very
> >nice, simple way to make an HTTP GET request that returns a image file
> >in the requested format. Such a request can be easily used in, for
> >example, the "src=" property of an <IMG> tag on the requesting page.
> >It can, of course, also be used in more complex environments where the
> >client/requester is a different sort of application than a simple HTML
> >viewer.
> > - Ed
> >Ed McNierney
> >ed at topozone.com
> >(978) 251-4242
> >On Behalf Of ANDY CANFIELD
> >Sent: Wednesday, September 15, 2004 10:45 AM
> >Subject: [UMN_MAPSERVER-USERS] Mapserver Web service questions
> >To anyone who may know,
> > Can Mapserver be used like a web service?
> >Here is my situation. I have a small device that I want to show maps
>on.
> >There are two ways I can do this as the device has a browser I can make
> >a small web page for it, or to give it more functionality I can write
> >an embeded app that displays maps from a web service.
> >So what I need to know is can Mapserver be used like a web service or
> >do I need to write a web service that acts as the interface to
>Mapserver?
> >I am using Mapserver for Windows and currently it's set up with php
> >Mapscript for my web maps.
> >If I can use Mapserver as a service can I use the same one I'm running
> >php Mapscript against?
> >If not and I write a service is it safe to target the same Mapserver as
> >php is using via it's Mapscript interface?
> >If it helps any the device sending the requests will be a Nextel
> >Blackberry.
> >The language of the app sitting on the device will be J2ME ( Java Micro
> >Edition ). The service itself if I have to write one will be in C++.
> >Any help or suggestions would be greatly appreciated.
> >Thanks,
> >Andy
> >_________________________________________________________________
> >Don't just search. Find. Check out the new MSN Search!
> >http://search.msn.click-url.com/go/onm00200636ave/direct/01/
Is your PC infected? Get a FREE online computer virus scan from McAfee®
Security. http://clinic.mcafee.com/clinic/ibuy/campaign.asp?cid=3963
