shpfile loading
Stefano Bonnin
stefano.bonnin at COMAI.TO
Fri Sep 17 04:03:29 EDT 2004
I have one spatial table (my_postgis_table) with a schema like
the_geom,object_name,object_id ......
I'd like to know if is possible in a simple way to load data from a generic shape file into "my_postgis_table".
The shp2pgsql load data into postgis spatial table creating a table with the same schema of the shape, so, the problem here is to "create a mapping" from shp file fields and my table.
The most simple way that I found is the following:
1) use the shp2pgsql loader in order to load the data into postgres spatial table (my_spatial_table_temp)
2) read the schema of "my_spatial_table_temp" and give to the user a page where to create the mapping between the 2 tables
Example:
my_spatial_table_temp.generic_field1 --> my_postgis_table.object_name
my_spatial_table_temp.generic_field2 --> my_postgis_table.object_name
and obviously:
my_spatial_table_temp.geom --> my_postgis_table.the geom
and so on ...
3) Excute the query that copies the gis data from my_spatial_table_temp to my_postgis_table using the mapping just created.
4) drop the "my_spatial_table_temp" table
is this the right way or exists another procedure more simple than this one?
Thanks in advance.
RedS
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20040917/5ccee660/attachment.html
