swig mapscript: your opinion on changing layerObj::getShape()
for version 4.4
Lowell Filak
lfilak at MEDINACO.ORG
Mon Sep 20 13:14:53 EDT 2004
The following message was sent by Sean Gillies <sgillies at FRII.COM> on
Mon, 20 Sep 2004 11:02:19 -0600.
> Hello mapscripters,
> For some time, an alternative API has been available to to those
> who build their own SWIG mapscript modules. I think it is time
> to make one feature of the experimental API permanent.
> In the experimental API getShape returns a shapeObj and takes
> shapeindex and tileindex as arguments.
> shapeObj getShape( int shapeindex [, int tileindex=-1 ] )
> The usage for the case of tileindexed shapefiles is like this
> tileindexed_layer.open()
> shape = tileindexed_layer.getShape(shapeindex, tileindex)
> tileindexed_layer.close()
> In the case of layers without tileindexing, the second argument
> can be omitted because it defaults to -1
> layer.open()
> shape = layer.getShape(shapeindex)
> layer.close()
> I'd like to get feedback on 2 facets of this proposal. The way
> I see it
> 1) return value change from int to shapeObj
> requires update of scripts: -1
> more like php mapscript: +1
> prevents shape type conflicts: +1
> reduces need to create shapes: +1
> just plain better: +1
> 2) reorder arguments
> less like php mapscript: -1
> for postgis layers avoids a useless argument: +1
> for regular shapefiles avoids useless arg: +1
> Please see this bug for more details:
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=878.
> cheers,
> Sean
Sean,
I vote for the change(s).
The method should just return a shape and not requiring the
documentation of a flag (-1) for things to work correctly are a good thing.
Lowell
