gdal 1.2.2 problem
Frank Warmerdam
warmerdam at POBOX.COM
Wed Sep 22 10:02:18 EDT 2004
Stefano Bonnin wrote:
> Hi all,
> I have just installed GDAL 1.2.2 with MapServer 4.2.3 and I get the
> following error:
> *Warning*: [MapServer Error]: msDrawMap(): Failed to draw layer named
> '@_ctr_icb' <mailto:'@_ctr_icb'>.
> *Warning*: [MapServer Error]: IReadBlock failed at X offset 0, Y offset
> 0: GDALRasterIO() failed: drawGDAL()
> this is a simple raster layer:
> Band 1 Block=3156x3154 Type=Byte, ColorInterp=Palette
> Color Table (RGB with 2 entries)
> 0: 255,255,255,255
> 1: 0,0,0,255
Stefano,
According to the above, the entire file is being treated as one big tile
which may be quite in-efficient and memory hungry. But I don't think that
is your problem. Perhaps you could place the file somewhere for me to
inspect?
I would also note that the libtiff support in GDAL 1.2.2 has been discovered
to have been incorrectly configured on Unix and will not include a number
of important compression types. (fax, packbits, deflate and LZW are missing
I think).
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
