DWG/DXF
ANDY CANFIELD
andy_canfield at HOTMAIL.COM
Wed Sep 22 18:50:48 EDT 2004
I've used the openDWG libraries along with OGR to read from AutoCAD dwg's
and write Mapinfo tables and ESRI shapefiles for use with Mapserver. I have
a once weekly batch that pulls all the design out of 1,400 drawings and puts
it into 14 or 15 shapefiles and Mapinfo tables. The application is
proprietary to the company I work for but if you have a specific question
about using the open DWG stuff I can probably answer it (as long as it's the
C++ libs, I have no idea about their VB stuff). I use their multi-threaded
static libs for what I do.
>From: David Bitner <bitner at MACNOISE.COM>
>Reply-To: David Bitner <bitner at MACNOISE.COM>
>To: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: [UMN_MAPSERVER-USERS] DWG/DXF
>Date: Wed, 22 Sep 2004 16:22:12 -0500
>About a year ago Frank Warmerdam wrote that he may have the opportunity to
>work on implementing DWG/DXF support in OGR via the OpenDWG toolkit. I was
>wondering if he, or anyone else has done anything with direct DWG access
>for
>mapserver?
>Thanks,
>David
_________________________________________________________________
Express yourself instantly with MSN Messenger! Download today - it's FREE!
hthttp://messenger.msn.click-url.com/go/onm00200471ave/direct/01/
