multipolygon set from oraclespatial crash with OGR
GIRAUD Pierre
bluecarto at FREE.FR
Fri Sep 24 05:51:44 EDT 2004
Frank Warmerdam wrote:
> GIRAUD Pierre wrote:
>> Hi list,
>> Today, I'm in front of a particular problem. For a customer, I need to
>> render oraclespatial data.
>> In the database, I have shapes with a '2007' SDO_GTYPE, that says
>> multipolygons. Hopelessly, in the SDO_ELEM_INFO_ARRAY, including the
>> polygons (2003), some points (1003) can be found. Curious for a
>> multipolygon, and you might want to say that it'd better be a Collection
>> (2004) ! But I can't modify data.
>> The problem is that if define my layer with an oraclespatial
>> connectiontype, the layer is rendered. On the other hand, with an
>> OGR/OCI connectiontype, mapserver crashes.
> Pierre,
> I'm not readily able to work on Oracle support just now. My NT partition
> with Oracle has become inaccessable due to an unfortunate "install"
> problem.
> My understanding from the code is that multipolygons should work in OGRs
> Oracle driver, but I am not sure how well tested it is. Does ogrinfo
> also crash against the layer in question? If so, I would suggest you
> submit a detailed bug including a snippet of SQL sufficient to create
> a one record table that will demonstrate the problem.
> That way I can fix it at some point when I have access to Oracle again.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
I just built an SQL statement that includes 8 multipolygon shapes (with
many different cases). 4 of them crash ogrinfo and OCI/OGR connection
for mapserver but not oraclespatial connection.
Defaultly, I might want to report a bug in OGR remotesensing bugzilla
(618), tell me if I'm wrong.
Pierre GIRAUD
