Generate map image names from PHP MapScript
Doug
ummmmm at MYREALBOX.COM
Wed Sep 29 16:53:50 EDT 2004
Lowell Filak wrote:
> The following message was sent by Doug <ummmmm at MYREALBOX.COM> on Wed, 29
> Sep 2004 10:41:30 -0500.
>>The NAME attribute in the .map file is used as the prefix for generated
>>images when using the CGI interface, but it isn't being used with our PHP
>>MapScript code. Those images just have the unique numeric identifier in
>>their file names. Is there any way to change this?
> Doug,
> If you're currently using saveWebImage() to save the file you could use
> saveImage(string filename) instead and be able to specify whatever you
> want for the name. I'm not sure there is any method available that would
> allow you to access the random saveWebImage string for use in saveImage
> or any way to tell saveWebImage to use prefix "X" when naming.
> HTH
> Lowell
Darn. That's what I was kind-of thinking. I just wanted confirmation. Thanks.
