Imagery TileIndex extent errors
ANDREW WOOLEY
AWOOLEY at MOUNTAINLAND.ORG
Thu Sep 30 11:11:04 EDT 2004
Folks,
I am using a raster tileindex that I created using gdaltindex and it
works very well. However, when I draw a portion of the map that the
index does not cover, I get this:
Fatal error: Object expected as argument. in
/var/www/html/bst/map/bstmap.phtml on line 548. Line 548 is the line
before the drawing of the map.
I don't get an error if I take out the entry in the mapfile for the
tiles or if I turn it off.
Is there a way I am using PHP/MapScript and would be fine if I could
turn it off through code, but I am not sure how to check to see if the
index is in the current extent.
Here is my mapserver info: MapServer version 4.2.0 OUTPUT=PNG
OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF SUPPORTS=PROJ SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Thanks in advance for any help you can offer.
Andrew Wooley
GIS Coordinator
Mountainland Association of Governments
586 E 800 N
Orem, UT 84097
ph: 801.229.3844
email: awooley at mountainland.org
web: http://maps.mountainland.org
