Is it possible to change the legend template via map_legend_template?
Daniel Morissette dmorissette at DMSOLUTIONS.CA
Thu Sep 30 12:59:44 PDT 2004
Ryan Grant wrote:
> In the form I initially submit to load my mapserver interface, if I add this:
> <INPUT type="hidden" name="map_legend_template" value="../legend_display.html">
> Mapserver crashes out when it gets to the [legend] section of my
> template. Can the legend be dynamically set like this?
I can't see any reason to explain the crash. Perhaps you should test
against against 4.3, and if it still crashes then please file a bug with
a complete testcase to reproduce the crash.
  Daniel Morissette               dmorissette at dmsolutions.ca
  DM Solutions Group              http://www.dmsolutions.ca/
More information about the MapServer-users mailing list
