WFS Server Layer Aggregation
Daniel Morissette
dmorissette at DMSOLUTIONS.CA
Thu Sep 30 16:55:05 EDT 2004
David Fawcett wrote:
> To those of you who added WFS support to MapServer.
> In a MapServer WFS Server instance, is it possible to build a Map file
> in a way that you aggregate many local data layers into one layer that
> can be requested from a WFS Client?
> I realize that you could do this with one or more tileindex's if your
> domain of layers was static, however, I am thinking of situations where
> a dynamic mapfile is used.
You mean presenting a group of individual layers as a single feature
type in the WFS capabilities?
There is no way to do that at the moment, and that would be a
complicated one to deal with. WFS assumes that all features in a given
layer (layer=FeatureType) share the same schema and MapServer needs to
be able to produce that schema on the fly in response to
(DescribeFeatureType). The GML output of a GetFeature also needs to
follow that common schema for all features in the response. If you allow
grouping of layers, then it's hard to enforce the requirement for a
common schema between layers. I think the best way to go is still the
tileindex.
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
