problem with Nad27 and NaD83 datum shift
Chris TheMapserverNewby
guyincognito at GMAIL.COM
Thu Sep 30 18:56:00 EDT 2004
I am trying to project NAD27 data to NAD83. I have downloaded the PROJ
files with NAD27/83 datum shift included and followed the directions as
detailed on the MapServer Wiki ProjHowTo (http://mapserver.gis.umn.edu/cgi-
bin/wiki.pl?WindowProjHowTo). But, the data is not reprojecting. I have
created a test map file and data sets (see bellow) to try to isolate the
issue...but to no avail. When I set the Map projection to NAD27(4267) the
NAD83 does not show up at all...and vice-versa.
Am I doing something wrong? Is their another test I can run?
thanks, chris
MAP
IMAGETYPE PNG
EXTENT -118.29 33.70 -118.28 33.71
SIZE 700 600
SHAPEPATH "data"
IMAGECOLOR 255 255 255
WEB
IMAGEPATH "c:/temp/img_tmp/"
IMAGEURL "/img_tmp/"
END
PROJECTION
"init=epsg:4269"
END
# LAYER
LAYER # States polygon NAD27
NAME states27
DATA nad27states
STATUS DEFAULT
TYPE POLYGON
PROJECTION
"init=epsg:4267"
END
CLASS
COLOR 100 232 232
OUTLINECOLOR 32 32 32
END
END
# End of LAYER
# Start of LAYER
LAYER # States polygon NAD83
NAME states83
DATA nad83states
STATUS DEFAULT
TYPE POLYGON
PROJECTION
"init=epsg:4269"
END
CLASS
COLOR 177 132 200
OUTLINECOLOR 90 90 90
END
END
# End of LAYER
END # end of map
