"msLoadMap(): Unable to access file. " Error Loading Map File
Jacob Delfos
jacob.delfos at MAUNSELL.COM
Fri Apr 1 02:23:16 EST 2005
Hi Jack,
Did you set up your permissions for Apache correctly? What statements did you add to your httpd.conf file?
You should check whether the file is accessable. Have you tried to load the url directly (http://localhost/mapserver_demos/workshop/itasca.map)?
Alternatively, change the path of your mapfile to a filepath (e.g. c:\\web\\mapfile.map). Best to use double-backslash with windows.
Regards,
Jacob
JACOB DELFOS
SPATIAL INFORMATION ANALYST
Maunsell Australia Pty Ltd
629 Newcastle Street, WA 6007
PO Box 81, WA 6902
Leederville
Western Australia
ABN 20 093 846 925
Tel + 61 8 9281 6185
Fax + 61 8 9281 6297
jacob.delfos at maunsell.com
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Jack Ling
Sent: 1 April 2005 15:15
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] "msLoadMap(): Unable to access file. " Error Loading Map File
I'm a newbie to MapServer, struggling to setup and try. I managed to
setup the MapServer w/ the expected return from initial install: "No
query information to decode. QUERY_STRING is set, but empty."
I' ve downloaded the demos and put in under Apache's htdocs -> i.e.
htdocs/mapserver_demos folder. When I run the demo i.e. the index page
of /workshop folder, it has the following message: -
All the files are there but I don't know why I can't access?
OS: Windows XP
Webserver: Apache2
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050401/01722844/attachment.html
