Map will not display
Jim Clavin
clavinji at YAHOO.COM
Sat Apr 2 16:43:11 EST 2005
Hello All,
Would appreciate your help. I am running Apache 2.0.53. I have run the
demos successfully. This is my first attempt with my own dataset.
I have included the .map file, the .phtml file, and a .txt generated by
ogrinfo on my .shp file.
Here is my .map file:
MAP
NAME COASTAL
SIZE 800 500
IMAGETYPE PNG
IMAGECOLOR 240 240 240
SHAPEPATH "C:\Program Files\Apache Group\Apache2\htdocs\data\"
EXTENT -78.275652 33.849300 -76.849048 35.038803
#UNITS METERS
# PROJECTION
#"proj=lcc"
#"lat_1=32"
#"lat_2=44"
#"lat_0=38"
#"lon_0=-100"
#"x_0=0"
#"y_0=0"
#"ellps=GRS80"
#"datum=NAD83"
#END
WEB
IMAGEPATH "C:\Program Files\Apache Group\Apache2\htdocs\temp\ms_temp"
IMAGEURL "/temp/ms_temp"
END
LAYER
NAME "North Carolina New Hanover Coastline"
TYPE POLYGON
STATUS DEFAULT
DATA "Coastlines"
#PROJECTION
# "proj=latlong"
# "ellps=GRS80"
# "datum=NAD83"
#END
CLASS
NAME "Counties"
EXPRESSION 'land'
OUTLINECOLOR 60 60 60
COLOR 255 255 0
SYMBOL 0
END
END
LAYER
NAME "credits"
STATUS DEFAULT
TRANSFORM FALSE
TYPE ANNOTATION
FEATURE
POINTS
10 480
END
TEXT 'Made with Mapserver.'
END
CLASS
LABEL
TYPE BITMAP
POSITION CR
COLOR 0 0 0
END
END
END
END
Here is my .phtml file:
<?php
dl("php_mapscript_44.dll");
$map_file="./coastal.map";
$map = ms_newMapObj($map_file);
$image=$map->draw();
$image_url=$image->saveWebImage();
<HTML>
<HEAD>
<TITLE>New Hanover County</TITLE>
</HEAD>
<BODY>
<img SRC="<?php echo $image_url?>">
<p>
This is a very simple example using only one data layer, a vector file.
You can download the datafile yourself from
the <a href="http://nationalatlas.gov/atlasftp.html">USGS National Atlas</a>.
The URL for this layer, the US States Boundaries in Shapefile format, is
<a
href="http://edcftp.cr.usgs.gov/pub/data/nationalatlas/statesp020.tar.gz">http://edcftp.cr.usgs.gov/pub/data/nationalatlas/statesp020.tar.gz</a>.
</p>
<p>This example also draws some unprojected, static text. You can use this
technique to label your maps: apply titles, timestamps, or copyright
information.</p>
<h3>Source for all recipes: <a
href="http://www.mobilegeographics.com/mapserver/MSrecipes.tar.gz">http://www.mobilegeographics.com/mapserver/MSrecipes.tar.gz</a></h3>
<iframe src="usa1.txt" width=450 height=400><a
href="usa1.txt">usa1.txt</a></iframe>
<h2><a href="http://www.mobilegeographics.com/mapserver/">return to
Mapserver Recipes</a></h2>
</BODY>
</html>
Here is my .txt file, generated by ogrinfo on my .shp file:
INFO: Open of `Coastlines.shp'
using driver `ESRI Shapefile' successful.
Layer name: Coastlines
Geometry: Line String
Feature Count: 25
Extent: (-78.275652, 33.849300) - (-76.849048, 35.038803)
Layer SRS WKT:
GEOGCS["GCS_WGS_1984",
DATUM["WGS_1984",
SPHEROID["WGS_1984",6378137.0,298.257223563]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.0174532925199433]]
OBJECTID: Integer (10.0)
DHT_OID: Integer (10.0)
LHT_OID: Integer (10.0)
F_CODE: String (5.0)
F_CODE_DES: String (255.0)
ACC: Integer (4.0)
ACC_DESCRI: String (20.0)
EXS: Integer (4.0)
EXS_DESCRI: String (50.0)
OGRFeature(Coastlines):0
OBJECTID (Integer) = 9783
DHT_OID (Integer) = 0
LHT_OID (Integer) = 0
F_CODE (String) = BA010
F_CODE_DES (String) = Coastline/Shoreline
ACC (Integer) = 1
ACC_DESCRI (String) = Accurate
EXS (Integer) = 1
EXS_DESCRI (String) = Definite
LINESTRING (-76.84904840 34.98498000,-76.86047360 34.98987580,-76.87091820
34.99805840)
OGRFeature(Coastlines):1
OBJECTID (Integer) = 9785
ACC (Integer) = 1
EXS (Integer) = 1
LINESTRING (-76.90056620 34.95346460,-76.90021520 34.95690540,-76.94039920
34.97190860,-76.95136260 34.98261260,-76.96627800 34.99084100,-76.97509000
34.99761580,-76.97743220 35.00000000,-76.98330680 35.00598520,-76.98326880
35.00828180,-76.96020500 35.03139880,-76.95170600 35.03748700,-76.94721220
35.03880320,-76.93942260 35.03709420,-76.93500520 35.03405000,-76.94120020
35.03160860,-76.93266300 35.02552420,-76.92681120 35.02475740,-76.92295080
35.02218240,-76.91896060 35.02603140,-76.91365820 35.02573020,-76.90708160
35.01921460,-76.88117220 35.00210180,-76.87531280 35.00179300,-76.87319940
35.00000000)
OGRFeature(Coastlines):2
OBJECTID (Integer) = 9786
ACC (Integer) = 1
EXS (Integer) = 1
LINESTRING (-76.89619440 34.94858560,-76.89144900 34.94852060,-76.88648220
34.94592660,-76.87444300 34.94759760,-76.86804960 34.94659040,-76.86254120
34.94284060)
OGRFeature(Coastlines):3
OBJECTID (Integer) = 9789
ACC (Integer) = 1
EXS (Integer) = 1
LINESTRING (-76.85399620 34.93744280,-76.84904840 34.93876320)
OGRFeature(Coastlines):4
OBJECTID (Integer) = 9796
ACC (Integer) = 1
EXS (Integer) = 1
LINESTRING (-77.03204340 34.67510220,-77.01937860 34.68320840,-77.02241520
34.68439480,-77.03672800 34.67745600,-77.03593440 34.67515180,-77.03204340
34.67510220)
OGRFeature(Coastlines):5
OBJECTID (Integer) = 9798
ACC (Integer) = 1
EXS (Integer) = 1
LINESTRING (-77.15934000 34.62979880,-77.15002440 34.63841240,-77.14555360
34.63974000,-77.13666540 34.63917920,-77.12937920 34.64276500,-77.12387080
34.63971720,-77.11936180 34.64333720,-77.11752320 34.63665780,-77.12370300
34.63305660,-77.14036560 34.63417060,-77.15573880 34.62906640,-77.15934000
34.62979880)
OGRFeature(Coastlines):6
OBJECTID (Integer) = 9799
ACC (Integer) = 1
EXS (Integer) = 1
LINESTRING (-77.16133120 34.62683480,-77.16464240 34.62825020,-77.16762540
34.62778860,-77.17473600 34.62308500,-77.17420960 34.62101360,-77.17116540
34.62029260,-77.16133120 34.62683480)
OGRFeature(Coastlines):7
OBJECTID (Integer) = 9802
ACC (Integer) = 1
EXS (Integer) = 1
LINESTRING (-77.65919500 34.34861380,-77.65217600 34.36056900,-77.64856720
34.36100000,-77.64456180 34.36708060)
OGRFeature(Coastlines):8
OBJECTID (Integer) = 9803
ACC (Integer) = 1
EXS (Integer) = 1
LINESTRING (-77.68233480 34.33622360,-77.68666840 34.33115380)
OGRFeature(Coastlines):9
OBJECTID (Integer) = 9804
ACC (Integer) = 1
EXS (Integer) = 1
LINESTRING (-77.68831640 34.32786180,-77.68615720 34.32751460,-77.68746180
34.32202920,-77.71648400 34.29790120)
OGRFeature(Coastlines):10
OBJECTID (Integer) = 9805
ACC (Integer) = 1
EXS (Integer) = 1
LINESTRING (-77.82119760 34.18793480,-77.81169900 34.19935600,-77.81334680
34.20143120,-77.82581320 34.19805900,-77.82418820 34.19345860,-77.82530980
34.19140240,-77.82119760 34.18793480)
OGRFeature(Coastlines):11
OBJECTID (Integer) = 9806
ACC (Integer) = 1
EXS (Integer) = 1
LINESTRING (-77.72320560 34.28991320,-77.77147680 34.24615860,-77.77476500
34.24939340,-77.77976220 34.24758520,-77.78362280 34.24921800,-77.78584280
34.24808500,-77.78145600 34.24346540,-77.77703100 34.24366760,-77.77652740
34.23838800,-77.79876700 34.20315560,-77.81103520 34.19020460,-77.81153100
34.19195180,-77.80198660 34.20388800,-77.79606620 34.21739200,-77.79882820
34.21786880,-77.80664060 34.20988080,-77.80912780 34.20920940,-77.81462860
34.21314240,-77.81707760 34.21774680,-77.82468420 34.21133800,-77.83230600
34.21154400,-77.84055320 34.21653740,-77.84616080 34.21545800,-77.84010320
34.21146780,-77.83711240 34.20665740,-77.83441160 34.20593260,-77.83547220
34.20284280,-77.83223720 34.20380400,-77.83020020 34.20378500,-77.82910920
34.20083240,-77.83639520 34.18848040,-77.83337400 34.18639760,-77.83181000
34.18320840,-77.82646180 34.18658820,-77.82572940 34.18221280,-77.82915500
34.17956920,-77.83020780 34.17620080,-77.83156580 34.17607120,-77.83222200
34.17804720,-77.83526620 34.17821120,-77.83597560 34.17568580,-77.83816520
34.17472080,-77.84557340 34.18083200,-77.84653480 34.18478020,-77.85141000
34.18848040,-77.85613260 34.18992620,-77.86120600 34.19081120,-77.86595160
34.19056700)
OGRFeature(Coastlines):12
OBJECTID (Integer) = 9807
ACC (Integer) = 0
ACC_DESCRI (String) = Unknown
EXS (Integer) = 0
EXS_DESCRI (String) = Unknown
LINESTRING (-77.86595160 34.19056700,-77.86361700 34.18773260,-77.85621640
34.18331140,-77.85233300 34.18187340,-77.84904480 34.17906580,-77.85510260
34.16426080)
OGRFeature(Coastlines):13
OBJECTID (Integer) = 9808
ACC (Integer) = 1
EXS (Integer) = 1
LINESTRING (-77.94718940 34.11332700,-77.94580840 34.11423880,-77.94632720
34.11906060,-77.95126340 34.12436300,-77.95402520 34.12391660,-77.95487980
34.12047960,-77.95297240 34.11679840,-77.94718940 34.11332700)
OGRFeature(Coastlines):14
OBJECTID (Integer) = 9809
ACC (Integer) = 1
EXS (Integer) = 1
LINESTRING (-77.94628900 34.08371740,-77.94351200 34.08576960,-77.94182580
34.09058000,-77.94564820 34.09679800,-77.94760900 34.09290320,-77.94628900
34.08371740)
OGRFeature(Coastlines):15
OBJECTID (Integer) = 9810
ACC (Integer) = 1
EXS (Integer) = 1
LINESTRING (-77.95083620 33.93847280,-77.94308480 33.94371420,-77.94718180
33.94878380,-77.95378880 33.95064920,-77.95083620 33.93847280)
OGRFeature(Coastlines):16
OBJECTID (Integer) = 9812
ACC (Integer) = 0
EXS (Integer) = 0
LINESTRING (-78.23641200 33.91332240,-78.22347260 33.91191480)
OGRFeature(Coastlines):17
OBJECTID (Integer) = 9813
ACC (Integer) = 1
EXS (Integer) = 1
LINESTRING (-77.96699520 33.91147240,-77.95566560 33.91623680,-77.95237740
33.91323860,-77.94590760 33.93386080,-77.94699860 33.93570320,-77.94892880
33.93502420,-77.95368960 33.92288200,-77.95702360 33.91945640,-77.95921320
33.92176060,-77.96555320 33.92110440,-77.96749880 33.91790000,-77.97025300
33.91836920,-77.97191620 33.91654200,-77.96699520 33.91147240)
OGRFeature(Coastlines):18
OBJECTID (Integer) = 9814
ACC (Integer) = 1
EXS (Integer) = 1
LINESTRING (-77.98767860 33.90720360,-77.97659300 33.91748040,-77.97520440
33.91999820,-77.97656240 33.92298880,-77.98455040 33.92256540,-77.99121860
33.91433340,-77.98819740 33.91294480,-77.98767860 33.90720360)
OGRFeature(Coastlines):19
OBJECTID (Integer) = 9815
ACC (Integer) = 1
EXS (Integer) = 1
LINESTRING (-78.27565160 33.90941620,-78.25046540 33.91220860,-78.24605560
33.91426460,-78.23999020 33.91379160)
OGRFeature(Coastlines):20
OBJECTID (Integer) = 9817
ACC (Integer) = 1
EXS (Integer) = 1
LINESTRING (-77.97075660 33.88211440,-77.96909340 33.88440320,-77.97341160
33.89773180,-77.97920220 33.89683920,-77.98252100 33.89479060,-77.99077600
33.89597320,-77.99161520 33.89368440,-77.98834220 33.88908000,-77.97544100
33.88213720,-77.97075660 33.88211440)
OGRFeature(Coastlines):21
OBJECTID (Integer) = 9821
ACC (Integer) = 1
EXS (Integer) = 1
LINESTRING (-77.96569820 33.84930000,-77.96177680 33.86601260,-77.95561220
33.88273240,-77.95380400 33.90636060,-77.95488740 33.90820320,-77.95710000
33.90752420,-77.95961000 33.90271760,-77.95970920 33.88780220,-77.96504980
33.87107460,-77.98494720 33.88256460,-77.98483280 33.87781900,-77.98758700
33.87714380,-77.99251560 33.88152700,-77.99166880 33.88565060,-77.99661260
33.88773720,-78.00133520 33.88110360,-78.00794980 33.87952800,-78.01406860
33.86922840,-78.01300040 33.86417380,-78.00423440 33.85587700,-77.98389440
33.85050960,-77.98116540 33.84930000)
OGRFeature(Coastlines):22
OBJECTID (Integer) = 9811
ACC (Integer) = 1
EXS (Integer) = 1
LINESTRING (-77.95594020 34.16959760,-77.95019540 34.16084680,-77.94587700
34.14453500,-77.93711860 34.13232800,-77.93415060 34.12267300,-77.93042000
34.10245900,-77.93270880 34.09053800,-77.92893980 34.07651900,-77.93093100
34.06803900,-77.92522440 34.05492780,-77.92641440 34.05123900,-77.92861180
34.04438780,-77.92484280 34.03037260,-77.92439280 34.01568220,-77.92754360
33.99940500,-77.92572780 33.98264320,-77.92826080 33.97554020,-77.93905640
33.96825020,-77.94407660 33.95978160,-77.93779760 33.95057300,-77.93815620
33.93841180,-77.93567660 33.93840020,-77.93241880 33.94057840,-77.93125160
33.94136420,-77.92623900 33.94822320,-77.91026300 33.98554620,-77.90732580
34.01077660,-77.88745120 34.06001280,-77.87680060 34.07189180,-77.84476480
34.14377600,-77.83555600 34.15519720,-77.83132180 34.16642000,-77.82205960
34.17151260,-77.81907660 34.17632300,-77.81941980 34.17734520,-77.82323460
34.17555240,-77.82537840 34.17438500,-77.83751680 34.16733160,-77.83974460
34.17004020,-77.84056100 34.16146860,-77.84837340 34.14775840,-77.84912880
34.15114600,-77.84938820 34.15344240,-77.85159300 34.15437320,-77.85414120
34.14589300,-77.86302940 34.14043420,-77.86525720 34.13792420,-77.86499780
34.13539880,-77.85695640 34.13925560,-77.85337060 34.13900380,-77.85504920
34.13557060,-77.86227420 34.13010400,-77.86364740 34.12932580,-77.86451720
34.12750620,-77.85993960 34.12802880,-77.85955040 34.12572860,-77.86233520
34.12229920,-77.86405940 34.11427680,-77.87103280 34.10490800,-77.86885080
34.10122300,-77.87107840 34.09870920,-77.87363440 34.08954240,-77.87918860
34.08498380,-77.87979120 34.07833100,-77.88648220 34.06941600,-77.89117440
34.06944280,-77.89574440 34.04881280,-77.89826200 34.04377740,-77.90102380
34.04333120,-77.90039820 34.05319600,-77.89221200 34.07839960,-77.88986200
34.09766380,-77.88345340 34.10612100,-77.88644400 34.11210260,-77.87838740
34.11848840,-77.87430580 34.13031000,-77.87047580 34.14139560,-77.86290740
34.15558240,-77.85510260 34.16426080)
OGRFeature(Coastlines):23
OBJECTID (Integer) = 9816
ACC (Integer) = 1
EXS (Integer) = 1
LINESTRING (-77.97253420 34.16760640,-77.97395320 34.16210560,-77.97124480
34.15291220,-77.95358280 34.10807800,-77.95371240 34.08834460,-77.94756320
34.05733100,-77.95204160 34.04840460,-77.95180520 34.04532240,-77.95102700
34.03508760,-77.95412440 34.02477640,-77.96223440 34.00783160,-77.96424860
33.99544900,-77.96298980 33.97685620,-77.96549220 33.97365180,-77.97846980
33.97027200,-77.99635320 33.93227380,-77.99690240 33.93111040,-78.00189980
33.92470940,-78.02261360 33.91630560,-78.03065500 33.90738680,-78.03394320
33.90946580,-78.04051200 33.91821280,-78.05082700 33.92501840,-78.05266580
33.92502980,-78.05268860 33.92288580,-78.04300680 33.91569900,-78.03665920
33.90745540,-78.03618620 33.90304940,-78.05373380 33.91849520,-78.07107540
33.92200460,-78.08677680 33.92251960,-78.08790580 33.91678620,-78.08681480
33.91379920,-78.08351140 33.91401680,-78.08019260 33.91698840,-78.06338500
33.91738520,-78.05815120 33.91621780,-78.04334260 33.90330880,-78.03345480
33.89913940,-78.02272040 33.89725880,-78.01805880 33.89425660,-78.01752480
33.89126960,-78.01890560 33.88990020,-78.03405000 33.89041900,-78.05249020
33.89393620,-78.06595620 33.89834600,-78.07238000 33.89947900,-78.12981420
33.90958780,-78.14385980 33.91123580,-78.17829140 33.91179660,-78.20116420
33.90979380,-78.20776360 33.91371160)
OGRFeature(Coastlines):24
OBJECTID (Integer) = 9801
ACC (Integer) = 1
EXS (Integer) = 1
MULTILINESTRING ((-77.64249420 34.36434560,-77.64751440
34.35805520,-77.64668280 34.35570900,-77.63972480 34.35864260,-77.63562780
34.36105340,-77.63164520 34.36339960,-77.61325080 34.38150400,-77.58860020
34.39727400,-77.56457520 34.41383740,-77.48022460 34.46328740,-77.45956420
34.47538380,-77.40205380 34.50217060,-77.35879520 34.51966100,-77.34819800
34.52602380,-77.34675600 34.52688980,-77.34104160 34.53831100,-77.33712000
34.54033660,-77.33524320 34.53572840,-77.33051300 34.53659820,-77.29863740
34.55211260,-77.25431820 34.58103180,-77.23497780 34.59184260,-77.23172760
34.59346000,-77.20473480 34.60689540,-77.18237300 34.61491020,-77.18085480
34.62269600,-77.17673500 34.62586600,-77.16564940 34.63164140,-77.15277100
34.64051060,-77.11389160 34.65406040,-77.10224160 34.66861340,-77.09793860
34.66030120,-77.10209660 34.64473720,-77.10103600 34.64197160,-77.08059700
34.65021900,-77.06531520 34.65473940,-77.05152140 34.65881720,-77.01495360
34.66662600,-76.98873900 34.67065040,-76.96925360 34.67131800,-76.93714140
34.67824180,-76.91616060 34.67989740,-76.87501520 34.68313600,-76.84904840
34.68855660),(-76.84904840 34.69541000,-76.85029600 34.69472880,-76.86092380
34.69212340,-76.87333680 34.69180680,-76.87845620 34.69167700,-76.89105220
34.68771740,-76.95881660 34.67921440,-76.97222900 34.67594900,-76.98666380
34.67751320,-76.99953460 34.67331700,-77.01760860 34.67354580,-77.02175140
34.67520520,-77.02239220 34.67503360,-77.04383080 34.66928100,-77.05384820
34.66871640,-77.06009680 34.67728800,-77.05342100 34.67743680,-77.05191040
34.68407440,-77.04798120 34.68609240,-77.04653160 34.68905640,-77.04402160
34.68948740,-77.04079440 34.68324660,-77.03804020 34.68183520,-77.03441620
34.68225100,-77.03044120 34.68656160,-77.02404020 34.68693920,-77.02121740
34.68897240,-77.01834100 34.69444280,-77.01277920 34.69437400,-77.01058200
34.69250860,-77.00501260 34.69289780,-76.99572000 34.69920740,-76.98200980
34.70339200,-76.98055260 34.70478820,-76.97634120 34.70882800,-76.96048740
34.70862200,-76.94698340 34.71625140,-76.94773860 34.72016140,-76.95544440
34.72462460,-76.95231620 34.72848520,-76.94246680 34.71940240,-76.92995460
34.71900560,-76.90864560 34.72698600,-76.90992740 34.73251340,-76.90437320
34.73220820,-76.89723200 34.72728720,-76.88889320 34.72648620,-76.87527460
34.72718040,-76.84989160 34.72846980,-76.84904840 34.72846480))
