WMS GetCapabilities problem
Wouter Schaubroeck
wouter.schaubroeck at GMAIL.COM
Sun Apr 3 17:41:05 EDT 2005
Many thanks,
Indeed you're right, i didn't look further than the name: mapserv.exe.
Why is it called like that? Can you give it a (file)name, other than
mapserv.exe?
grtz
Wouter
Kralidis,Tom [Burlington] wrote:
>This is because the MIME type returned by an OGC:WMS 1.1.1
>GetCapabilities request is not recognized by standard web browsers
>unless you configure it to do so.
>Try saving the file and opening with something like Wordpad.
>..Tom
>-----Original Message-----
>From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
>Behalf Of Wouter Schaubroeck
>Sent: Sunday, 03 April, 2005 16:45
>To: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: [UMN_MAPSERVER-USERS] WMS GetCapabilities problem
>Hi all,
>I'm using the ms4w application you all know. I worked myself through the
>tutorial, and now i want to set up my own WMS Server. Therefor i used
>example 1.7. But when i want to test my WMS Server and perform a
>GetCapabilities request, Firefox is offering me the mapserv.exe file, in
>stead of an XML document. What am i doing wrong?
>This is my hyperlink with the request:
>http://192.168.2.3/cgi-bin/mapserv.exe?map=c:/ms4w/apache/htdocs/mapserv
>ertutorial/example1-7.map&SERVICE=WMS&VERSION1.1.1&REQUEST=G
>etCapabilities
>This is my MAP file:
>MAP
>NAME EX1.7_
>IMAGETYPE PNG24
>#EXTENT 201621.496941 -294488.285333 1425518.020722 498254.511514
># LAEA
>EXTENT -97.5 41.619778 -82.122902 49.38562 # Geographic
>SIZE 400 300
>SHAPEPATH "c:\ms4w\apache\htdocs\mapservertutorial\data"
>SYMBOLSET
>"c:\ms4w\apache\htdocs\mapservertutorial\symbols\symbols35.sym"
>FONTSET
>"c:\ms4w\apache\htdocs\mapservertutorial\fonts\fonts.list"
>WEB
> IMAGEPATH 'c:\tmp\'
> IMAGEURL '\tmp\'
> METADATA
> "wms_title" "WMS_Test"
> "wms_onlineresource"
>"http://192.168.2.2/cgi-bin/mapserv.exe?map=c:\ms4w\apache\htdocs\mapser
>vertutorial\example1-7.map&"
> "wms_srs" "EPSG:2136"
> END
>END
>PROJECTION
># "proj=laea"
># "ellps=clrk66"
># "lat_0=45"
># "lon_0=-100"
># Alternatively, you can specify an EPSG code.
> "init=epsg:2163"
>END
># Start of LAYER DEFINITIONS
>LAYER # States polygon layer begins here
> NAME states
> DATA states_ugl
> STATUS OFF
> TYPE POLYGON
> PROJECTION
> "init=epsg:4326"
> END
> METADATA
> "wms_title" "States Polygon"
> "wms_srs" "epsg:4326"
> END
> CLASSITEM "CLASS"
> CLASS
> EXPRESSION 'land'
> SYMBOL 0
> COLOR 232 232 232
> END
>END # States polygon layer ends here
>LAYER # MODIS raster layer begins here
> NAME modis
> DATA "raster\mod09a12003161_ugl_ll_8bit.tif"
> STATUS OFF
> TYPE RASTER
> PROCESSING "BANDS=1,2,3"
> OFFSITE 71 74 65
># PROJECTION
># "init=epsg:4326"
># END
>END # MODIS raster layer ends here
>LAYER # LandSat WMS map from JPL (or from USGS)
> NAME LandSat
> TYPE RASTER
> OFFSITE 0 0 0
> STATUS DEFAULT
> CONNECTIONTYPE WMS
> #CONNECTION
>"http://wms.jpl.nasa.gov/wms.cgi?REQUEST=map&LAYERS=us_landsat7&STYLES=&
>FORMAT=png&TRANSPARENT=true" #verwijder de 1!!
> CONNECTION
>"http://gisdata.usgs.net/servlet/com.esri.wms.Esrimap?ServiceName=USGS_W
>MS_LANDSAT7&VERSION=1.0.0&REQUEST=map&Layers=LANDSAT7&SRS=EPSG:4326&REAS
>PECT=false&Format=png&"
> METADATA
> "wms_title" "LandSat"
> "wms_name" "us_landsat7"
> "wms_server_version" "1.0.0"
> "wms_format" "image/png"
> #"wms_title" "US_Landsat7"
> # "wms_srs" "epsg:4326"
> # "wms_connectiontimeout" "1000"
> END
># PROJECTION
># "init=epsg:4326"
># END
>END # LandSat WMS image ends here
>LAYER # States line layer begins here
> NAME states
> DATA states_ugl
> STATUS DEFAULT
> TYPE LINE
># PROJECTION
># "init=epsg:4326"
># END
> CLASSITEM "CLASS"
> CLASS
> EXPRESSION 'land'
> SYMBOL 'line5'
> COLOR 64 64 64
> SIZE 1
> END
>END # States line layer ends here
>LAYER # States label layer begins here
> NAME states
> DATA states_ugl
> STATUS DEFAULT
> TYPE ANNOTATION
># PROJECTION
># "init=epsg:4326"
># END
> CLASSITEM "CLASS"
> LABELITEM "STATE"
> CLASS
> EXPRESSION 'land'
> COLOR -1 -1 -1
> LABEL
> COLOR 255 255 255
> TYPE TRUETYPE
> FONT arial-bold
> SIZE 12
> ANTIALIAS TRUE
> POSITION CL
> PARTIALS FALSE
> MINDISTANCE 300
> BUFFER 4
> END # end of label
> END # end of class
>END # States label layer ends here
># End of LAYER DEFINITIONS -------------------------------
>END # end of map file
