Problems w/ MapScript C#
Sean Gillies
sgillies at FRII.COM
Mon Apr 4 11:03:39 EDT 2005
On Apr 3, 2005, at 9:49 PM, Ian Erickson wrote:
> I've successfully built the C# Mapscript assembly, and have
> successfully
> written code that generates an image file to disk. Everything seems to
> work just fine until I make repeated calls to the map.draw() function.
> I get the following exception after 3 or 4 calls to the private member
> function drawMapImage():
> System.NullReferenceException: Object reference not set to an instance
> of an object.
> at mapscriptPINVOKE.mapObj_draw(IntPtr jarg1)
> at mapObj.draw()
> at SimpleMap.Form1.drawMapImage()
[snip]
Ian,
When you say "repeated calls", do you mean that these are sequential or
concurrent?
I (with no other info) interpret the exception to be saying that
"jarg1" is Null. As far as I can tell from the C# mapscript_wrap.c
file this is a reference to the mapObj. Are you destroying your mapObj
instance in the middle of your calls to drawMapImage()?
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
