MySQL and mapfile
Don Deskins
dldeskins at GMAIL.COM
Tue Apr 5 11:41:37 EDT 2005
Hello,
Again, I am new to mapserver. I have finally gotten my map to display
properly but it is very slow, so I am interested in getting all of the data
into a database (MySQL).
I have data (in .shp, .dbf, and .shx files) that I have converted using
mygisimport. This produce an sql file which I imported into the MySql db.
I am now having trouble accessing this data with the mapfile. Here is what
I have:
LAYER
NAME "SCAP_Cert2004_ParcelsUTM16M"
CONNECTIONTYPE mygis
CONNECTION "host:user:password:db:bin:"
#geo is the name of the column
DATA "geo from Parcels feature"
STATUS ON
TYPE POLYGON
CLASS
OUTLINECOLOR 255 0 0
TEMPLATE "template.html"
END
MAXSCALE 40000
TOLERANCE 0
TOLERANCEUNITS PIXELS
END
I get the following error:
Warning: [MapServer Error]: SELECT feature.id, feature.vertices,
geometry.WKB_GEOMETRY from bad mysql query : bad mysql query in <filepath
and name> on line 217
Can anyone help with this?
BTW, I tried to use shp2mysql.pl, but got several failures.
Thanks,
Don
