Label layer...
Jeff Portwine
jdport at VERITIME.COM
Wed Apr 6 09:24:20 EDT 2005
I generally make 2 layers.. one of type point, and one of type annotation.
You can choose whether or not to display the annotation layer at any time
without affecting the point layer at all.
Here is an example that i pulled out of one of my map files, and edited to
make an example.
LAYER
Name cities
DATA citiesx020
STATUS default
TYPE point
PROJECTION
"proj=latlong"
END
CLASS
NAME "Cities"
symbol "circle"
color 0 0 0
END
END
LAYER
NAME city_name_labels
DATA citiesx020
STATUS default
TYPE annotation
LABELITEM "name"
PROJECTION
"proj=latlong"
END
CLASS
LABEL
FORCE TRUE
COLOR 0 0 0
SIZE tiny
POSITION CC
PARTIALS false
END
END
Hope that helps.
-Jeff
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Wednesday, April 06, 2005 8:59 AM
Subject: [UMN_MAPSERVER-USERS] Label layer...
Hi, I have a point layer with a label... I´d like to know how can I
turn on/turn off only the label ... May I do other layer ? Sample??
I´m using php/mapscript
Thank you
LAYER
NAME state
TYPE POINT
STATUS ON
CONNECTIONTYPE POSTGIS
CONNECTION "user=x password=x dbname=x host= x"
DATA "the_geom from states"
LABELITEM "name"
LABELCACHE ON
CLASS
NAME "state_"
OUTLINECOLOR 255 0 0
COLOR 10 90 10
SYMBOL 'circle'
SIZE 5
LABEL
FONT fritqat
SIZE 6
TYPE TRUETYPE
COLOR 255 0 0
FORCE TRUE
OUTLINECOLOR 255 200 200
PARTIALS TRUE
POSITION AUTO
END
END
