Unexpected WFS GetFeature results
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Wed Apr 6 13:09:13 EDT 2005
Assefa,
I tested this scenario with CVS 20050328 (the day before you committed
to mapogcfilter.c and mapogcfilter.h), and everything works fine.
So the problem is somewhere in those changes.
Here's the actual OGC filter:
<Filter>
<And>
<BBOX>
<PropertyName>NAME</PropertyName>
<Box srsName="EPSG:4326">
<coordinates>-141.84,21.599999999999994 -56.16,74.16</coordinates>
</Box>
</BBOX>
<Or>
<Or>
<PropertyIsLike wildCard="*" singleChar="." escape="!">
<PropertyName>title</PropertyName>
<Literal>benthic</Literal>
</PropertyIsLike>
<PropertyName>abstract</PropertyName>
</PropertyIsLike>
</Or>
<PropertyName>keywords</PropertyName>
</PropertyIsLike>
</Or>
</And>
</Filter>
..Tom
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of
> Yewondwossen Assefa
> Sent: Wednesday, 06 April, 2005 13:03
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] Unexpected WFS GetFeature results
> Tom,
> I did make some changes recently to the way filters were
> handled for postgis layers (Bug
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1292).
> It's probably related to thoses changes. Is it easy for you
> to test it against 4.4.x releases ? If you can test and It
> works I will start looking into the code to see what the problem is.
> Later,
> Kralidis,Tom [Burlington] wrote:
> > Hi,
> > (MapServer CVS, FC2, latest stable supporting libs).
> > I have a WFS instance running against a PostGIS table, and when I
> > invoke a Filter'd GetFeature operation (bbox AND a nested OR), I
> > expect one result to be returned (only one record in the DB
> satisfies
> > this request).
> > I've attached a sample HTML form page to correctly invoke
> the request.
> > However, I receive all records back in the DB.
> > Any idea what's going on here? FYI, here's my DATA string in the
> > LAYER
> > object:
> > DATA "the_geom from (select service_endpoints.organization as
> > organization,service_endpoints.endpoint_getresource as
> > endpoint_getresource,service_endpoints.service_type as
> > service_type,service_endpoints.service_version as
> > service_version,service_resources.the_geom as
> > the_geom,service_resources.resource_id as
> > resource_id,service_resources.service_id as
> > service_id,service_resources.name as
> name,service_resources.title as
> > title,service_resources.abstract as
> > abstract,service_resources.keywords
> > as keywords,service_resources.dataurl as
> > dataurl,service_resources.metadataurl as
> > metadataurl,service_resources.legendurl as
> > legendurl,service_resources.scale_min as
> > scale_min,service_resources.scale_max
> > as scale_max,service_resources.srs as
> srs,service_endpoints.format_list
> > as format_list,service_resources.style_list as
> > style_list,service_resources.time_extent as
> > time_extent,service_resources.queryable as queryable from
> > service_resources inner join service_endpoints on
> > service_endpoints.service_id =
> service_resources.service_id) as t using
> > unique resource_id"
> > Thanks
> > ..Tom
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax: (613) 565-0925
