Mapserver SVG output
Frank Warmerdam
fwarmerdam at GMAIL.COM
Thu Apr 7 06:57:08 PDT 2005
On Apr 7, 2005 5:15 AM, James Anderson <james at danisat.net> wrote:
> Hi,
> I am having this problem with mapserver trying it get it to make svg output:
> In browser the mapfile produces:
> loadOutputFormat(): General error message. OUTPUTFORMAT clause references
> driver svg, but this driver isn't configured.
> How do I configure the svg driver?
> Can anyone please help ?
James,
I just took a quick look at this and it seems the SVG driver isn't
yet built in by default. You need to manually add -DUSE_SVG in
your FLAGS macro in the Makefile.
I have also committed a change in maperror.c so that OUTPUT=SVG
will be reported if SVG support is configured in.
Assefa ... is there a reason SVG support isn't enabled by default?
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
More information about the MapServer-users
