access to Mapinfo
Bart van den Eijnden
BEN at SYNCERA-ITSOLUTIONS.NL
Thu Apr 7 11:34:19 EDT 2005
you need to use OGR for that:
See:
http://www.maptools.org/dl/docs/mapserv/MsVectorDataGuide.pdf
Just use Mapscript to set the respective properties of the LAYER object.
Best regards,
Bart
Syncera-ITSolutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> Leonardo Olivieri <lolivieri at IMTEAM.IT> 04/07/05 05:30pm >>>
hi,
I use PHP/mapscript.
Till now I have used shapefile and I succeed in getting information on the shapes.
Now I use the file Mapinfo (TAB,MAP,..) and I don't know how to find again information.
Is there some example or does someone have some available code?
thanks in advance
LO
