Mapserver SVG output
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Thu Apr 7 13:39:39 EDT 2005
The USE_SVG has been removed in the latest CVS.
I also added bug http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1307
to update the linux makefiles to add a USE_ZLIB flag that is necessary
to be able to output compressed svg files using zlib functions.
Later,
Frank Warmerdam wrote:
> On Apr 7, 2005 5:15 AM, James Anderson <james at danisat.net> wrote:
>>Hi,
>>I am having this problem with mapserver trying it get it to make svg output:
>>In browser the mapfile produces:
>>loadOutputFormat(): General error message. OUTPUTFORMAT clause references
>>driver svg, but this driver isn't configured.
>>How do I configure the svg driver?
>>Can anyone please help ?
> James,
> I just took a quick look at this and it seems the SVG driver isn't
> yet built in by default. You need to manually add -DUSE_SVG in
> your FLAGS macro in the Makefile.
> I have also committed a change in maperror.c so that OUTPUT=SVG
> will be reported if SVG support is configured in.
> Assefa ... is there a reason SVG support isn't enabled by default?
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
