Identify WMS Layers with ArcGIS
Bart van den Eijnden
BEN at SYNCERA-ITSOLUTIONS.NL
Fri Apr 8 17:16:35 EDT 2005
Hi Eduin,
the known issues with ArcGIS as a WMS client are reported here:
http://support.esri.com/index.cfm?fa=knowledgebase.techArticles.articleShow&d=27825
I don't see your bug in the list, so I would suggest you use the ESRI forum or ESRI support to report this issue.
Best regards,
Bart
Syncera-ITSolutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> Eduin Carrillo <yecarrillo at YAHOO.COM> 04/08/05 22:27 PM >>>
Looking with HttpLook, problem seems to be caused by ArcGIS. WMS compliant
servers requieres the "LAYERS" parameter in the request. However, ArcGIS just
includes "QUERY_LAYERS", something like:
http://www.example.com/cgi-bin/mapserv?VERSION=1.1.1&REQUEST=GetFeatureInfo&SRS=EPSG:21892&BBOX=869977.952111551,1027721.7482033,1369773.31499998,1393306.32833008&WIDTH=715&HEIGHT=523&QUERY_LAYERS=municipio&STYLES=&EXCEPTIONS=application/vnd.ogc.se_xml&&INFO_FORMAT=text/html&FEATURE_COUNT=50&X=381&Y=289
HTTP/1.1
Adding manually "LAYERS" parameter to this request, causes mpaserver return a
valid html response.
Somebody knows the state of ArcGIS as a compliant WMS server?
Eduin Yesid Carrillo Vega
yecarrillo at yahoo.com
COLOMBIA
_________________________________________________________
Do You Yahoo!?
Información de Estados Unidos y América Latina, en Yahoo! Noticias.
Visítanos en http://noticias.espanol.yahoo.com
