shp2tile question
Don Deskins
dldeskins at GMAIL.COM
Mon Apr 11 14:54:06 EDT 2005
Stephen,
Thank you for your reply.
what is the tile2ms command in your answer? I do not find it on
google or this list
Thanks again.
On Apr 11, 2005 1:01 PM, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> Don Deskins wrote:
> > hello, another newbie question.
> > My project has large shp files (2 are greater than 1 gig). My obvious
> > solution to the speed problem was to tile the shp files.
> > After (finally) getting shp2tile compiled, I tried several different option
> > combinations and got what were to me unexpected results. What I expected
> > was some kind of world file for each tile and then use shptree to index the
> > files. What I got of course was a series of shp files.
> If you just want to index your shapefile then use shptree shapefile.shp
> > My questions are as follows:
> > 1. How do I figure out how many rows and colums to use in the shp2tile
> > program? The shp file contains approx 54000 shapes.
> There is no magic number. If you data is spread evenly over the area
> then you can expect row*col tile or about 54000/(row*col) in each tile.
> You might have to try some different sizes to get something you are
> happy with.
> > 2. If i use the quadtree option, how do I know what value to use?
> Pick the number so that is is as large as possible and that you are
> displaying most of the records for each map draw. That way you open the
> least number of files and you use most all of the objects in each file
> you open. Sorry, no magic number.
> > 3. Is there a way to create an index on the shp files that are produced
> > with the shp2tile program, so that I do not have to create a layer for each
> > shp file?
> After you run shp2tile also run:
> find /path/to/files -name "*.shp" -exec shptree {} \;
> find /path/to/files -name "*.shp" > tileindex.in
> tile2ms tileindex.in tileindex
> shptree tileindex
> and now you can reference you files in a single layer using:
> TILEINDEX "tileindex"
> -Steve
> > 4. What else am I missing?
> > Thanks,
> > Don
Don Deskins
