shp2tile question
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Mon Apr 11 15:32:56 EDT 2005
Don,
The layer should probably be more like this, change to suit your needs:
LAYER
NAME "parcels"
STATUS ON
TYPE POLYGON
TILEINDEX 'path/to/tileindex'
MAXSCALE 40000
CLASS
COLOR 255 255 0
OVERLAYCOLOR 0 0 0
END
END
-Steve
Don Deskins wrote:
> Bart (and Steve),
> Thanks.
> I have my files created and tried to reference this index in my map file:
> # parcels
> LAYER
> NAME 'tileindex'
> TYPE TILEINDEX
> DATA '/path/to/tileindex'
> MAXSCALE 40000
> END
> LAYER
> NAME 'SCAP_Cert2004_ParcelsUTM16M'
> STATUS ON
> TYPE POLYGON
> TILEINDEX '/path/to/tileindex'
> #TILEITEM 'LOCATION'
> MAXSCALE 40000
> END
> I get no error but my shapes are not showing up... do you see a
> problem with the above map?
> Don
> On Apr 11, 2005 2:58 PM, Bart van den Eijnden <bartvde at xs4all.nl> wrote:
>>Hi,
>>It is tile4ms, not tile2ms, probably a typo by Steve.
>>It is a Mapserver utility to make a tileindex. Alternatively, you can also
>>use ogrtindex for vector layers and gdaltindex for raster layers.
>>Best regards,
>>Bart
