Projections with Different Units
Ed McNierney
ed at TOPOZONE.COM
Mon Apr 11 19:21:10 EDT 2005
Rick -
You have three different entities in play here - the STATES input layer,
the ORTHOS input layer, and the output map image itself. If you leave
out all PROJECTION blocks, then all entities are presumed to have the
same projection. If you only specify a PROJECTION for the output map,
then all layers are presumed to use that same projection. If you
specify two layers with different projections, then you also need to
specify the PROJECTION you want for the output map image. That
projection can be the same as either of the two input layers, or a
different projection entirely.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
Phone: +1 (978) 251-4242
Fax: +1 (978) 251-1396
ed at topozone.com
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Rick Powers
Sent: Monday, April 11, 2005 5:17 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Projections with Different Units
I'm trying to display layers with different projections and units. There
was another good post on multiple UTM projections that I will use.
But an example of my case is State Boundaries (LatLong-Decimal Degrees)
and Terra Server WMS DOQs (UTMs-Meters). I can make both work
independently, but each wants the shared map object to provide
appropriate units. Any suggestions?
NAME MULTI
STATUS ON
SIZE 400 300
SYMBOLSET symbols/symbol.sym
#EXTENT -126 24 -64 50
#UNITS DD
EXTENT 189600 1976600 818200 5478800
UNITS METERS
SHAPEPATH "data"
IMAGETYPE JPEG
IMAGECOLOR 255 255 204
FONTSET etc/fonts.txt
LAYER
NAME STATES
METADATA
WMS_TITLE "Cartgographic Boundaries of United States States"
WMS_ABSTRACT "US Census"
WMS_SRS "EPSG:4326"
"RESULT_FIELDS" "NAME st99_d00"
END
GROUP Admin
STATUS ON
DATA cont_states
TYPE POLYGON
TRANSPARENCY 60
CLASS
# COLOR 31 62 21
OUTLINECOLOR 31 62 21
TEMPLATE "ttt_query.html"
END
PROJECTION
"init=epsg:4326"
END
END
LAYER
NAME ORTHOS
GROUP DOQ
STATUS ON
TYPE RASTER
MINSCALE 10000
MAXSCALE 264000
CONNECTIONTYPE WMS
CONNECTION "http://terraservice.net/ogcmap.ashx?"
METADATA
"wms_srs" "EPSG:26910"
"wms_title" "Orthophoto"
"wms_name" "DOQ"
"wms_server_version" "1.1.1"
"wms_format" "image/png"
"wms_layers" "doq"
"wms_group_title" "background"
END
PROJECTION
"init=epsg:26910"
END
END
