maps.google.com - Speed
Gregor Mosheh
stigmata_blackangel at YAHOO.COM
Mon Apr 11 19:24:13 EDT 2005
--- "Shanton, James A" <James.Shanton2 at NSCORP.COM>
wrote:
> Is there anyway to speed this system up like
> maps.google.com ? I'm having
> speed issues displaying my database layers.
I presume you mean PostGIS tables. For starters, make
sure you have the appropriate indexes created on your
PostGIS table. There are basicallly three indexes to
consider:
- an index on the oid column. this is used internally
by MapServer and PostGIS and makes a HUGE difference.
- a GIST index on the geometry column (probably called
the_geom) is obviously useful, and makes a huge
difference.
- if your layer uses a FILTER to select only certain
records, make sure those columns have indexes
I hope that helps.
__________________________________
Do you Yahoo!?
Yahoo! Small Business - Try our new resources site!
http://smallbusiness.yahoo.com/resources/
