Perl API method setProjection doesn't work.
Shantha, Raghavendra Vasanth
raghu at KU.EDU
Tue Apr 12 12:15:19 EDT 2005
Try using $map->setProjection('(proj=eqc,lat_ts=50,lon_0=80)')
(notice the braces)
I had a similar problem with clssObj.setExpression
-Raghu
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Trond Michelsen
Sent: Tuesday, April 12, 2005 9:38 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Perl API method setProjection doesn't
work.
On Tue, Apr 12, 2005 at 06:23:15PM +0400, Cave wrote:
> Here if I use any projection except "lonlat", the output file contains
> an empty image. If this projection is set in a cgi-script, everything
> is displayed correctly.
> If I comment this string:
> $map->setProjection('proj=eqc,lat_ts=50,lon_0=80')
Are you sure this a valid proj4 string?
try:
$map->setProjection('proj=eqc lat_ts=50 lon_0=80')
or
$map->setProjection('+proj=eqc +lat_ts=50 +lon_0=80')
Trond Michelsen
