queryByAttributes...
Sean Gillies
sgillies at FRII.COM
Tue Apr 12 14:48:36 EDT 2005
On Apr 12, 2005, at 12:07 PM, Paul james wrote:
> Thank you Sean... I thoung '1' means sucess ...
> so, my queryByAttributes() is always returning 1 (Failure)... I dont
> know why... I think is problem with any parameter...
> string value = "'[state]' = 'test'";
> layer.queryByAttributes(mp,"state", value, 0)
> I have a state column in my table : > state varchar
> And I have a 'test' line as well ... And the 'test' point is in my
> extents mp ...
> so, any other idea?
> thank you...
> On Apr 12, 2005 2:45 PM, Sean Gillies <sgillies at frii.com> wrote:
>> On Apr 12, 2005, at 11:17 AM, Paul james wrote:
>>> I=B4m with problems using queryByAttributes... getResult(0) always
>>> return n=
>>> ull...
>>> any idea?
>>> ps.: using c#
>>> thx
>>> =20
>>> layer =3D mp.getLayerByName("layer");
>>> string value =3D "'[oid]' =3D '32141'";
>>> if ((layer.queryByAttributes(mp,"oid", value, 0))=3D=3D1)
>>> resultCacheMemberObj result =3D new resultCacheMemberObj();
>>> result =3Dlayer.getResult(0);
>> Is it just me, or is the listserv mangling this (and other) emails?
>> I'm assuming you are using MapServer 4.4. First, of all, you should
>> generally compare integer results from mapscript to
>> mapscript.MS_SUCCESS (0) and mapscript.MS_FAILURE (1). Second, I
>> think
>> you really should be doing something like this:
>> layerObj layer = mp.getLayerByName("layer");
>> layer.queryByAttributes(...);
>> resultCacheObj results = layer.getResults();
>> if (results)
>> resultCacheMemberObj result = results.getResult(0);
>> Keep in mind that the extents of your 'mp' map are used to filter
>> results. If you query by attributes for a feature outside the map
>> extents, it will not be found.
>> cheers,
>> Sean
1 is just a number :) MapServer follows an old C convention for
success and failure.
I overlooked that you have a PostGIS layer. The qstring parameter of
queryByAttributes becomes, during the query, the layer's filter. You
can't use a mapserver logical expression for a postgis layer filter.
You must use a snippet of SQL instead, like this:
string qstring = "state = 'test'";
layer.queryByAttributes(mp, "state", qstring, 0);
the qstring is turned into an SQL clause: "WHERE state = 'test'". So
that's the crux of it, use your layer's specific filter syntax in
queryByAttributes.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
