queryByAttributes...
Sean Gillies
sgillies at FRII.COM
Tue Apr 12 17:48:42 EDT 2005
On Apr 12, 2005, at 3:11 PM, Sean Gillies wrote:
> On Apr 12, 2005, at 3:02 PM, Morten Nielsen wrote:
>>> First, of all, you should
>>> generally compare integer results from mapscript to
>>> mapscript.MS_SUCCESS (0) and mapscript.MS_FAILURE (1)
>> For some reason SWIG "hides" these return values in
>> MapServer.MS_RETURN_VALUE.MS_SUCCESS and
>> MapServer.MS_RETURN_VALUE.MS_FAILURE
>> /Morten
> I'm looking in mapscript.cs and see a
> public class mapscript {
> public static readonly int MS_SUCCESS
> Is that not accessible as mapscript.MS_SUCCESS from C#?
> Sean
It appears that SWIGCSHARP emits different C# code in 1.3.24 (Morten's)
than in 1.3.21 (mine). Bummer. I think that the "new" location of the
constants is awkward and that we should consider some changes to map.h
that will return them to a better location.
Sean
