Projection problem after upgrade from 4.2 to 4.4
Kevin Grootendorst
kgrootendorst at BAIRD.COM
Wed Apr 13 11:44:33 EDT 2005
I just recently upgraded from: MS 4.2 and PHP 4.3.4 to MS 4.4 and PHP
4.3.7. I also upgraded to Proj 4.4.9
The application (built using MapLab 2.2) was running smoothly before the
upgrade, but now I'm presented with the error:
PHP Fatal error: [MapServer Error]: msProcessProjection(): projection not
named in C:\web\maplab-2.2
\projects\gmf_apps\GreatLakes\wrapper\map_session.php on line 845
Line 845 is: $this->oMap->setprojection(implode( "\n", split( " ", $aszKeys
["SRS"] ) ));
My original projection info in the map file was:
PROJECTION
#"init=epsg:4269" #NAD 83
"SRS=epsg:4269" #NAD 83
END
If I use "init=epsg:4269", then the app loads but no map is ever displayed.
If I comment out both, then everything works fine (all data is in NAD 83).
However, I may want to reproject on the fly later on.
My epsg file contains the parameters for NAD 83.
Can anybody shed some light on this?
Thanks,
Kevin
