Segmentation fault: PHP Mapscript related?
Toomas Aas
toomas.aas at RAAD.TARTU.EE
Wed Apr 13 14:36:23 EDT 2005
BC Rocks wrote:
> PHP was configured as follows (as I am successfully using on another
> box): ./configure --build=i686-mandrake-linux-gnu --prefix=/usr
> --exec-prefix=/usr --bindir=/usr/bin --sbindir=/usr/sbin
> --sysconfdir=/etc --datadir=/usr/share --includedir=/usr/include
> --libdir=/usr/lib --libexecdir=/usr/lib --localstatedir=/var/lib
> --sharedstatedir=/usr/com --mandir=/usr/share/man
> --infodir=/usr/share/info --enable-discard-path
> --enable-force-cgi-redirect --enable-shared --disable-static
> --disable-debug --disable-rpath --enable-pic
> --enable-inline-optimization --enable-memory-limit
> --with-config-file-path=/etc --with-config-file-scan-dir=/etc/php
> --with-pear=/usr/share/pear --enable-magic-quotes --enable-debugger
> --enable-track-vars --with-exec-dir=/usr/bin --with-versioning
> --with-mod_charset --with-regex=php --enable-track-vars
> --enable-trans-sid --enable-safe-mode --enable-ctype --enable-ftp
> --with-gettext=/usr --enable-posix --enable-session --enable-sysvsem
> --enable-sysvshm --enable-yp --with-openssl=/usr --without-kerberos
> --with-ttf --with-freetype-dir=/usr/include/freetype2
> --with-zlib=/usr --with-zlib=/usr --with-zlib-dir=/usr --with-pear
> --with-jpeg-dir=/usr --with-png-dir=/usr --with-gd
> --enable-gd-native-ttf --with-pgsql=/var/lib/pgsql/ --without-iodbc
> --without-custom-odbc --without-unixODBC --without-dbmaker
> --enable-soap --with-xml=/usr/include/libxml2/libxml
> --with-apxs2=/usr/sbin/apxs2 --with-mcrypt=/usr/local/lib
> --with-curl=/usr/local/include
> Mapserver configure parameters are as follows: ./configure
> --with-php=/usr/include/php
> --with-php-regex-dir=/usr/src/php/php-5.0.4/regex
> --with-jpeg=/usr/lib --with-png=/usr/lib
> --with-freetype=/usr/bin/freetype-config --with-proj --with-gd
> --without-pdf --with-geos=/usr/local/bin/geos-config --with-gdal
> --with-postgis=/var/lib/pgsql/bin/pg_config --without-tiff
> --with-wmsclient --with-wfsclient --with-wcs
> --with-curl-config=/usr/bin --with-ogr --with-httpd=/usr/sbin/httpd2
I notice that you have used --with-gd both when compiling PHP and Mapserver.
Actually, you should use something like --with-gd=/usr when compiling
PHP. Otherwise PHP gets compiled with it's bundled version of GD, and
php_mapscript.so gets compiled with whatever version of GD is found at
build time. If these versions don't match exactly, nasty things can happen.
Substitute the real path where GD is installed instead of /usr, of course.
To be really sure, use the same path when compiling Mapserver. If you
have only one version of GD installed on your system, it shouldn't
matter, but better safe than sorry.
> I read some threads with regard to GDAL and JPG/TIFF issues (I did
> try using the internal GDAL libs), but I don't think that is the
> issue... especially since if I pull the php, things compile.
This seems a likely indication of conflicting GD versions between PHP
and Mapserver.
Toomas
