shapefile polygon opens in arcgis but not mapserver
Bart van den Eijnden
bartvde at XS4ALL.NL
Wed Apr 13 15:18:12 EDT 2005
It should work if you are using Mapserver 4.4 or later.
Otherwise try showing it through OGR.
CONNECTIONTYPE OGR
CONNECTION "path/my.shp"
Best regards,
Bart
On Wed, 13 Apr 2005 16:45:50 -0230, gerard barrington
<gerard_b_18 at HOTMAIL.COM> wrote:
> I checked with ogrinfo and the shapefile is a <3D POLYGON>. Other shape
> files I have show up simply as <POLYGON> when checked with ogrinfo. Is
> there anything i can do to show this polygon in mapserver?
>> From: Bart van den Eijnden <bartvde at XS4ALL.NL>
>> Reply-To: Bart van den Eijnden <bartvde at XS4ALL.NL>
>> To: MAPSERVER-USERS at LISTS.UMN.EDU
>> Subject: Re: [UMN_MAPSERVER-USERS] shapefile polygon opens in arcgis
>> but not
> mapserver
>> Date: Wed, 13 Apr 2005 20:32:42 +0200
>> Hi,
>> are you sure it is not a polyline shape? Did you try TYPE LINE?
>> Otherwise open it up with ogrinfo and see what it says
>> (http://fwtools.maptools.org).
>> Best regards,
>> Bart
>> On Wed, 13 Apr 2005 16:04:39 -0230, gerard barrington
>>> Hi list, I have a polygon shapefile which I can open and view in
>>> ArcExplorer and everything looks perfect. However, when I try to
>>> use the
>>> same shapefile as data for a LAYER of TYPE POLYGON, I get the
>>> following
>>> exception: msDrawMap(): Image handling error. Failed to draw layer
>>> named
>>> 'aal135'. msDrawShape(): General error message. Only polygon shapes
>>> can
>>> be drawn using a POLYGON layer definition. So I tried switching the
>>> TYPE
>>> in my layer to POINT and a couple of points along the border of the
>>> polygon showed up. I know the shapefile is a polygon though because
>>> it
>>> displays as the correct shape in arcExplorer. Can someone tell me
>>> why
>>> the polygon will show up in ArcExplorer but not in mapserver? Is
>>> there
>>> anything I can do to fix this problem?? I am at real loss here for
>>> why
>>> this happens and would really appreciate any help.... Thanks Gerard
>>> B
>> Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
