Still on Example 1.9
Pericles S. Nacionales
nacional at CBS.UMN.EDU
Wed Apr 13 15:52:42 EDT 2005
OK, let me butt in on this. First, I have to make many assumptions as I don't
know if you change any of the directory structure of the tutorial. I'm
assuming you didn't and that you unzipped it under "/ms4w/apps". This would
give you a directory "/ms4w/apps/tutorial" and everything will be set there
save the Apache configuration. My second assumption is that you have created
an "httpd_tutorial.conf" Apache config file in "/ms4w/httpd.d" and that this
file contains something like:
Alias /tutorial "/ms4w/apps/tutorial"
<Directory "/ms4w/apps/tutorial">
AllowOverride None
Options Indexes MultiViews
Order allow,deny
Allow from all
</Directory>
If you haven't read the README_HTTPD.txt under /ms4w/httpd.d, you should do
so.
The last assumption I'll make is that you didn't change the MS4W temp
directory so that it's still under /ms4w/tmp/ms_tmp.
OK then, have a look at your IMAGEPATH and IMAGEURL parameters... Your
IMAGEPATH should point to "/ms4w/tmp/ms_tmp/"--that's your local path. Your
IMAGEURL then should point to "/ms_tmp/"--that's how it's referenced in an
HTTP url (the Alias in Apache). These paths should be explained in MS4W
README somewhere in your installation. It's also explained in the WMS
example (example 1.6?).
Finally, you have your SHAPEPATH pointing to "/ms4w/httpd.d/tutorial/data".
Did you install the tutorial in the httpd.d directory? If so, you might want
to move the whole tutorial to "/ms4w/apps"--that's where your MapServer
applications are supposed to be. You can then edit your httpd_tutorial.conf
to have the lines I have above. This is just something to follow to keep
your MS4W installation clean.
I hope this helps.
Good luck!
Perry
On Wednesday 13 April 2005 06:28 am, Lawal Olanrewaju wrote:
> The mapfile is as found below
> MAP
> NAME EX1.9_
> IMAGETYPE PNG24
> EXTENT 201621.496941 -294488.285333
> 1425518.020722 498254.511514 # LAEA
> #EXTENT -97.5 41.619778 -82.122902 49.38562 #
> Geographic
> SIZE 400 300
> SHAPEPATH "\ms4w\httpd.d\tutorial\data"
> SYMBOLSET "symbols/symbols35.sym"
> FONTSET "fonts/fonts.list"
> WEB
> TEMPLATE 'example1-9.html'
> IMAGEPATH '/data/tmp/'
> IMAGEURL '/tmp/'
> END
> PROJECTION
> # "proj=laea"
> # "ellps=clrk66"
> # "lat_0=45"
> # "lon_0=-100"
> # Alternatively, you can specify an EPSG code.
> "init=epsg:2163"
> END
> # Start of LAYER DEFINITIONS
> LAYER # States polygon layer begins here
> NAME states
> DATA states_ugl
> STATUS OFF
> TYPE POLYGON
> PROJECTION
> "init=epsg:4326"
> END
> CLASSITEM "CLASS"
> CLASS
> EXPRESSION 'land'
> SYMBOL 0
> COLOR 232 232 232
> END
> END # States polygon layer ends here
> LAYER # MODIS raster layer begins here
> NAME modis
> DATA "raster/mod09a12003161_ugl_ll_8bit.tif"
> STATUS DEFAULT
> TYPE RASTER
> PROCESSING "BANDS=1,2,3"
> OFFSITE 71 74 65
> PROJECTION
> "init=epsg:4326"
> END
> END # MODIS raster layer ends here
> LAYER # LandSat WMS map from JPL (or from USGS)
> NAME LandSat
> TYPE RASTER
> OFFSITE 0 0 0
> STATUS OFF
> CONNECTIONTYPE WMS
> #CONNECTION
> "http://wms.jpl.nasa.gov/wms.cgi?REQUEST=map&LAYERS=us_landsat7&STYLES=&FOR
>MAT=png&TRANSPARENT=true" CONNECTION
> "http://gisdata.usgs.net/servlet/com.esri.wms.Esrimap?ServiceName=USGS_WMS_
>LANDSAT7&VERSION=1.0.0&REQUEST=map&Layers=LANDSAT7&SRS=EPSG:4326&REASPECT=fa
>lse&Format=png&"
> METADATA
> "wms_title" "LandSat"
> "wms_name" "us_landsat7"
> "wms_server_version" "1.0.0"
> "wms_srs" "epsg:4326"
> "wms_format" "image/png"
> #"wms_title" "US_Landsat7"
> # "wms_srs" "epsg:4326"
> # "wms_connectiontimeout" "1000"
> END
> PROJECTION
> "init=epsg:4326"
> END
> END # LandSat WMS image ends here
> LAYER # States line layer begins here
> NAME states
> DATA states_ugl
> STATUS DEFAULT
> TYPE LINE
> PROJECTION
> "init=epsg:4326"
> END
> CLASSITEM "CLASS"
> CLASS
> EXPRESSION 'land'
> SYMBOL 'line5'
> COLOR 64 64 64
> SIZE 1
> END
> END # States line layer ends here
> LAYER # States label layer begins here
> NAME states
> DATA states_ugl
> STATUS DEFAULT
> TYPE ANNOTATION
> PROJECTION
> "init=epsg:4326"
> END
> CLASSITEM "CLASS"
> LABELITEM "STATE"
> CLASS
> EXPRESSION 'land'
> COLOR -1 -1 -1
> LABEL
> COLOR 255 255 255
> TYPE TRUETYPE
> FONT arial-bold
> SIZE 12
> ANTIALIAS FALSE
> POSITION CL
> PARTIALS FALSE
> MINDISTANCE 300
> BUFFER 4
> END # end of label
> END # end of class
> END # States label layer ends here
> # End of LAYER DEFINITIONS
> END # end of map file
> --- Ferencik Ioan <ferencik.ioan at PERSONAL.RO> wrote:
> > The problem could be your IMAGEPATH and IMAGEURL
> > properties from the WEB object
> > try to send the map file in message
> > > Hi Everyone
> > > I am new to Mapserver and I have just downloaded
> > the
> > > Tutorial (Mapserver 4.0)
> > > I could see the static map but not the dynamic
> > one,
> > > there was 'Submit query' displayed in the box
> > where
> > > the dynamic map was suppose to be displayed.
> > > I have a feeling the mapfil is alright since I was
> > > able to see the static map but I could not figure
> > out
> > > what was wrong with the html file.
> > > I hope someone can help me out.
> > > Best regards
> > > Olanrewaju Lawal
> > > Institute for Soil Science and Land Evaluation
> > (310)
> > > University of Hohenheim
> > > 70599, Stuttgart
> > > Germany
> > > Office. +497114593633
> > > Mob. +491632677964
> > > Webpage: http://larrylaw1.tripod.com/index.htm
> > > Send instant messages to your online friends
> > http://uk.messenger.yahoo.com
> > _____________________________________________
> > Cinefil?Castiga o excursie la Venetia
> > http://www.cineplus.ro/concurs
> Send instant messages to your online friends http://uk.messenger.yahoo.com
Dept. of Ecology, Evolution, and Behavior
University of Minnesota
work: 612 624 6713
e-mail: nacional at cbs.umn.edu
