Labels not displaying
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Thu Apr 14 11:54:17 EDT 2005
Also look at your extents, they appear to be in some projection, it is
unlikely that your uk_airports and airports are in that same projection.
What are the extents of your shapefiles?
shpdump uk_airports | head
shpdump airports | head
or use:
gdalinfo uk_airports
-Steve W.
Camden Daily wrote:
> from a quick glance, you're pointing the two layers at two different
> data files, "airports" and "uk_airports". are they really two
> seperate files?
> -camden
> On 4/14/05, sc <sc at bytron.com> wrote:
>>Hi
>>I have managed to get several layers switched on and off via mapscript/php
>>but I am unable to see any labels whose text comes from my shapefile.
>>I can annotate the map directly with TEXT (), but cannot get labelitem to
>>work within
>>my "Codes" Layer.
>>here is my mapfile:
>>thanks
>>Simon
>>MAP
>> NAME UK
>> STATUS ON
>> SIZE 1000 1000
>> IMAGETYPE PNG
>> IMAGECOLOR 240 240 240
>> SHAPEPATH "/usr/local/apache/htdocs/map/data/conic"
>> EXTENT -994934.821920 5173124.716504 322333.423383 6431993.097353
>> SYMBOL
>> NAME 'circle'
>> TYPE ELLIPSE
>> POINTS 1 1 END
>> FILLED TRUE
>> END
>> WEB
>> IMAGEPATH "/usr/local/apache/htdocs/tmp/"
>> IMAGEURL "/tmp/"
>> END
>> LAYER
>> NAME "Airports"
>> GROUP airfields
>> TYPE POINT
>> STATUS DEFAULT
>> DATA "airports"
>> CLASSITEM "ICAODesign"
>> CLASS
>> NAME "UKAIRPORTS"
>> STYLE
>> OUTLINECOLOR 60 60 60
>> COLOR 255 0 0
>> SYMBOL 'circle'
>> SIZE 4
>> END
>> END
>> END
>> LAYER
>> NAME "Codes"
>> TYPE ANNOTATION
>> DATA "uk_airports"
>> STATUS DEFAULT
>> LABELITEM "ICAODesign"
>> CLASS
>> LABEL
>> FORCE TRUE
>> SIZE MEDIUM
>> POSITION CC
>> PARTIALS TRUE
>> COLOR 0 0 0
>> END
>> END
>> END
>> LAYER
>> NAME "credits"
>> STATUS DEFAULT
>> TRANSFORM FALSE
>> TYPE ANNOTATION
>> FEATURE
>> POINTS
>> 10 480
>> END
>> TEXT 'Map of the United Kingdom and Ireland'
>> END
>> FEATURE
>> POINTS
>> 10 500
>> END
>> TEXT 'By SC'
>> END
>> CLASS
>> LABEL
>> TYPE BITMAP
>> POSITION CR
>> COLOR 0 0 0
>> END
>> END
>> END
>>END
>>No virus found in this outgoing message.
>>Checked by AVG Anti-Virus.
>>Version: 7.0.308 / Virus Database: 266.9.9 - Release Date: 13/04/2005
