Unexpected WFS GetFeature results
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Thu Apr 14 12:02:54 EDT 2005
> -----Original Message-----
> From: Yewondwossen Assefa [mailto:assefa at dmsolutions.ca]
> Sent: Thursday, 14 April, 2005 11:55
> To: Kralidis,Tom [Burlington]
> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] Unexpected WFS GetFeature results
> Tom,
> I have rechecked the code and when not using SQL statements, the
> filter encoding colde would create in your case :
> <PropertyIsLike wildCard="*" singleChar="." escape="!">
> <PropertyName>keywords</PropertyName>
> <Literal>benthic</Literal>
> </PropertyIsLike> :
> - a class item called "keywords"
> - expression /benthic/
> The expression built like that would match your field value defined
> like "cabin,benthic,canada,biomonitoring,sites,site,sample,".
> The expression generation could be thighten up to be
> /^benthic$/. If
> that is the inteded interpretation, please file a speperate
> bug on this
> and assigh it to me.
...but isn't this what is happening now? If I apply:
...then I get no results. If I apply:
<Literal>*benthic*</Literal>
...then I get results.
My interpretation of the Filter spec PropertyIsLike construct is that
you need wildcards to do wildcard searches.
..Tom
> Thanks for testing. Bug 1308 is closed.
> Later,
> Kralidis,Tom [Burlington] wrote:
> > Close out on this thread:
> > It seems that, before the changes to mapogcfilter.c, the
> like filter
> > evaluated directives like:
> > like 'benthic'
> > To:
> > Like '%benthic%'
> > ...whereas this was tightened up in the changes.
> > So my original test case with the GetFeature filter was getting
> > results back when it shouldn't have, i.e. now MapServer
> only applies
> > wildcards around the search term if put forth by the client.
> > Thanks Assefa!
> > ..Tom
> >>From: UMN MapServer Users List
> >>[mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of
> >>Yewondwossen Assefa
> >>Sent: Wednesday, 06 April, 2005 13:16
> >>To: MAPSERVER-USERS at LISTS.UMN.EDU
> >>I will look today into it and provide you with the exact SQL
> >>statment created if I do not see any thing obvious.
> >>Later,
> >>>Assefa,
> >>>I tested this scenario with CVS 20050328 (the day before
> >>you committed
> >>>to mapogcfilter.c and mapogcfilter.h), and everything works fine.
> >>>So the problem is somewhere in those changes.
> >>>Here's the actual OGC filter:
> >>><Filter>
> >>> <And>
> >>> <BBOX>
> >>> <PropertyName>NAME</PropertyName>
> >>> <Box srsName="EPSG:4326">
> >>> <coordinates>-141.84,21.599999999999994
> >>-56.16,74.16</coordinates>
> >>> </Box>
> >>> </BBOX>
> >>> <Or>
> >>> <Or>
> >>> <PropertyName>title</PropertyName>
> >>> </PropertyIsLike>
> >>> <PropertyName>abstract</PropertyName>
> >>> </PropertyIsLike>
> >>> </Or>
> >>> </PropertyIsLike>
> >>> </Or>
> >>> </And>
> >>></Filter>
> >>>..Tom
> >>>>On Behalf Of Yewondwossen Assefa
> >>>>Sent: Wednesday, 06 April, 2005 13:03
> GetFeature results
> >>>>Tom,
> >>>> I did make some changes recently to the way filters were
> >>handled for
> >>>>postgis layers (Bug
> >>>>http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1292).
> >>>> It's probably related to thoses changes. Is it easy for
> >>you to test
> >>>>it against 4.4.x releases ? If you can test and It works I
> >>will start
> >>>>looking into the code to see what the problem is.
> >>>>Later,
> >>>>>Hi,
> >>>>>(MapServer CVS, FC2, latest stable supporting libs).
> >>>>>I have a WFS instance running against a PostGIS table, and when I
> >>>>>invoke a Filter'd GetFeature operation (bbox AND a nested OR), I
> >>>>>expect one result to be returned (only one record in the DB
> >>>>satisfies
> >>>>>this request).
> >>>>>I've attached a sample HTML form page to correctly invoke
> >>>>the request.
> >>>>>However, I receive all records back in the DB.
> >>>>>Any idea what's going on here? FYI, here's my DATA string in the
> >>>>>LAYER
> >>>>>object:
> >>>>> DATA "the_geom from (select service_endpoints.organization as
> >>>>>organization,service_endpoints.endpoint_getresource as
> >>>>>endpoint_getresource,service_endpoints.service_type as
> >>>>>service_type,service_endpoints.service_version as
> >>>>>service_version,service_resources.the_geom as
> >>>>>the_geom,service_resources.resource_id as
> >>>>>resource_id,service_resources.service_id as
> >>>>>service_id,service_resources.name as
> >>>>name,service_resources.title as
> >>>>>title,service_resources.abstract as
> >>>>>abstract,service_resources.keywords
> >>>>>as keywords,service_resources.dataurl as
> >>>>>dataurl,service_resources.metadataurl as
> >>>>>metadataurl,service_resources.legendurl as
> >>>>>legendurl,service_resources.scale_min as
> >>>>>scale_min,service_resources.scale_max
> >>>>>as scale_max,service_resources.srs as
> >>>>srs,service_endpoints.format_list
> >>>>>as format_list,service_resources.style_list as
> >>>>>style_list,service_resources.time_extent as
> >>>>>time_extent,service_resources.queryable as queryable from
> >>>>>service_resources inner join service_endpoints on
> >>>>>service_endpoints.service_id =
> >>>>service_resources.service_id) as t using
> >>>>>unique resource_id"
> >>>>>Thanks
> >>>>>..Tom
> >>>>Assefa Yewondwossen
> >>>>Software Analyst
> >>>>Email: assefa at dmsolutions.ca
> >>>>http://www.dmsolutions.ca/
> >>>>Phone: (613) 565-5056 (ext 14)
> >>>>Fax: (613) 565-0925
> >>Assefa Yewondwossen
> >>Software Analyst
> >>Fax: (613) 565-0925
> Assefa Yewondwossen
> Software Analyst
> Fax: (613) 565-0925
