shapefile polygon opens in arcgis but not mapserver
Bart van den Eijnden
bartvde at XS4ALL.NL
Thu Apr 14 14:20:00 EDT 2005
Gerard,
does your LOCATION item in your tile-index dbf have c:\shapefile or
c:\shapefile.shp? Looking at your error message it looks like the first
option which is incorrect.
You can also try c:\shapefile.shp,0 in the LOCATION field.
Hope this helps.
Best regards,
Bart
On Thu, 14 Apr 2005 14:47:48 -0230, gerard barrington
<gerard_b_18 at HOTMAIL.COM> wrote:
> hi, using the ogr worked out for a POLYGON layer that did not have a
> tiledindex. The following worked perfect: LAYER
> NAME "name"
> TYPE POLYGON CONNECTIONTYPE OGR CONNECTION "C:\shapefile.shp" ... END
> However, this will not work for tiledindex. On the doc page for OGR it
> says the following should work but it does not. LAYER
> NAME "nam"
> TYPE POLYGON
> CONNECTIONTYPE OGR
> TILEINDEX "C:\tiledindex.shp"
> ... END The first entry in the tiled index is for c:\shapefile.shp but
> it returns the following error: msDrawMap(): Image handling error.
> Failed to draw layer named 'nam'. msOGRFileOpen(): OGR error. Open
> failed for OGR connection `c:\shapefile'. File not found or unsupported
> format. Any ideas why the tiledindex wouldn't work? I have used
> tiledindexes for points and lines and it works fine. Thanks again!
> Gerard B.
>> From: Bart van den Eijnden <bartvde at XS4ALL.NL>
>> Reply-To: Bart van den Eijnden <bartvde at XS4ALL.NL>
>> To: MAPSERVER-USERS at LISTS.UMN.EDU
>> Subject: Re: [UMN_MAPSERVER-USERS] shapefile polygon opens in arcgis
>> but not
> mapserver
>> Date: Wed, 13 Apr 2005 21:18:12 +0200
>> Hi,
>> It should work if you are using Mapserver 4.4 or later.
>> Otherwise try showing it through OGR.
>> CONNECTIONTYPE OGR
>> CONNECTION "path/my.shp"
>> Best regards,
>> Bart
>> On Wed, 13 Apr 2005 16:45:50 -0230, gerard barrington
>>> I checked with ogrinfo and the shapefile is a <3D POLYGON>. Other
>>> shape
>>> files I have show up simply as <POLYGON> when checked with ogrinfo.
>>> Is
>>> there anything i can do to show this polygon in mapserver?
>>>> arcgis
>>>> but not
>>> mapserver
>>>> Date: Wed, 13 Apr 2005 20:32:42 +0200
>>>> Hi,
>>>> are you sure it is not a polyline shape? Did you try TYPE LINE?
>>>> Otherwise open it up with ogrinfo and see what it says
>>>> (http://fwtools.maptools.org).
>>>> Best regards,
>>>> Bart
>>>> On Wed, 13 Apr 2005 16:04:39 -0230, gerard barrington
>>>>> Hi list, I have a polygon shapefile which I can open and view in
>>>>> ArcExplorer and everything looks perfect. However, when I try to
>>>>> use the
>>>>> same shapefile as data for a LAYER of TYPE POLYGON, I get the
>>>>> following
>>>>> exception: msDrawMap(): Image handling error. Failed to draw
>>>>> layer
>>>>> named
>>>>> 'aal135'. msDrawShape(): General error message. Only polygon
>>>>> shapes
>>>>> can
>>>>> be drawn using a POLYGON layer definition. So I tried switching
>>>>> the
>>>>> TYPE
>>>>> in my layer to POINT and a couple of points along the border of
>>>>> the
>>>>> polygon showed up. I know the shapefile is a polygon though
>>>>> because
>>>>> it
>>>>> displays as the correct shape in arcExplorer. Can someone tell me
>>>>> why
>>>>> the polygon will show up in ArcExplorer but not in mapserver? Is
>>>>> there
>>>>> anything I can do to fix this problem?? I am at real loss here
>>>>> for
>>>>> why
>>>>> this happens and would really appreciate any help.... Thanks
>>>>> Gerard
>>>>> B
>>>> Using Opera's revolutionary e-mail client:
>>>> http://www.opera.com/m2/
>> Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
