Could not find config.h or php_config.h in /usr
Camden Daily
cdaily at GMAIL.COM
Fri Apr 15 09:53:31 EDT 2005
Did you build PHP from source? I think you need to to compile
mapscript. I may be wrong, but if you installed from RPM, I think you
could just try again after installing the php-devel package (if there
is one).
Otherwise, make sure your --with-php= points to the directory with the
PHP source code in it.
-Camden
On 4/14/05, joÿffffffffffe3o Antunes <bluetuna_goes_skying at yahoo.co.uk> wrote:
> Hello everybody,
> I am trying to compile Mapserver on Linux RedHat9
> having already apache, php installed and running in my
> system.
> I am using the option --with-php=/usr/include in
> configure command so that I can compile the module for
> mapscript as well..
> I keep getting this error message:
> !!! Could not find config.h or php_config.h in /usr.
> !!! Has PHP been configured yet?
> I know this problem has been discussed earlier but
> found no solution..
> Can someone give a clue on how to solve this?
> thank you so much
> Joao Antunes
> Send instant messages to your online friends http://uk.messenger.yahoo.com
