GDAL virtual raster file
Frank Warmerdam
fwarmerdam at GMAIL.COM
Fri Apr 15 08:50:17 PDT 2005
On 4/14/05, Nuno Gil <nunoragil at gmail.com> wrote:
> Frank,
> Ok, so if I understand you correctly one layer calls the original
> full-res tiles and then another one call the overviews.
> My overview files have an "ovr" extension and when creating the index
> file for them I get
Nuno,
The mapserver "overview" layer wouldn't be using the overviews
built for the full res files. Those are automatically used by GDAL.
The objective of using a separate layer in MapServer is so that
you can have an overview that is "all-in-one" file. What is killing
you with showing overviews of 300 files worth of data is all the
per-file overhead. This is modest for 1 or 5 files, but open 300
GeoTIFF files, and parsing all the headers ends up being quite a
bit of work.
So, the overview layer should refer to a single big overview at
a much reduced resolution from the original files. The tricky
part is building this overview, as I mentioned before. There are
a variety of approaches, but for my money the easiest is to use
Mapserver itself. Do you need details on this process? I have
never *actually* done it myself.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
More information about the MapServer-users
