Search returned no results
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Sun Apr 17 10:52:57 EDT 2005
Try setting tolerance in the LAYER object (i.e. TOLERANCE 10).
..Tom
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Jeffrey Johnson
> Sent: Sunday, 17 April, 2005 09:36
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] Search returned no results
> I'm having trouble getting query mode to work in my first
> mapserver application. The standard "msQueryByPoint(): Search
> returned no results. No matching record(s) found. " is
> returned. The map file and template seem pretty simple and
> straightforward. I checked that img.x and img.y are being
> passed. Not sure whats up. Any ideas?
> Jeff
> ----Map File-----
> MAP
> NAME SDNHMPaleo
> STATUS ON
> SIZE 800 600
> EXTENT 6150763 1775304 6613436 2129759
> UNITS METERS
> SHAPEPATH "/home/www/sdnhmpaleo/data"
> IMAGECOLOR 230 230 230
> SYMBOLSET 'symbols.sym'
> FONTSET "fonts/fonts.list"
> DEBUG ON
> IMAGETYPE PNG
> WEB
> HEADER 'header.html'
> FOOTER 'footer.html'
> TEMPLATE 'map.htm'
> IMAGEPATH '/home/www/sdnhmpaleo/temp/'
> IMAGEURL '/sdnhmpaleo/temp/'
> MINSCALE 50000
> MAXSCALE 5000000
> LOG '/home/www/sdnhmpaleo/sdnhmpaleo.log'
> END
> SCALEBAR
> IMAGECOLOR 255 255 255
> LABEL
> COLOR 0 0 0
> SIZE TINY
> END
> STYLE 1
> SIZE 300 10
> COLOR 0 0 0
> UNITS MILES
> INTERVALS 2
> TRANSPARENT FALSE
> STATUS EMBED
> POSITION LR
> END
> LAYER
> NAME geology
> DATA cal-geol2
> STATUS OFF
> TYPE POLYGON
> CLASSITEM 'ptype'
> LABELITEM 'ptype'
> CLASS
> EXPRESSION 'water'
> COLOR 190 232 255
> OUTLINECOLOR 0 0 0
> END
> CLASS
> EXPRESSION 'Q'
> COLOR 255 255 179
> OUTLINECOLOR 0 0 0
> END
> *** More classes here ***
> END
> LAYER
> NAME roads
> DATA SD-Freeways2
> STATUS OFF
> TYPE LINE
> CLASS
> COLOR 0 0 0
> END
> END
> LAYER
> NAME localities
> DATA localities
> STATUS OFF
> TYPE POINT
> CLASS
> SYMBOL 'circle'
> COLOR 255 0 0
> MINSIZE 5
> END
> END
> END
> ----End Map File-----
> ----HTML Template-----
> <HTML>
> <head>
> <title> SDNHM Paleo Collection WebGIS - Sample Map</title>
> </head> <body bgcolor='ffffff'> <font color='000000'
> face="arial, helvetica"> <form name="mapserv" method="POST"
> action="/cgi-bin/mapserv"> <input type="hidden" name="map"
> value="[map]"> <input type="hidden" name="imgext"
> value="[mapext]"> <table border=0 cellspacing=5> <tr> <td
> valign = top> <center><b>LEGEND</b></center><br>
> <input type="checkbox" name="layer" value="localities"
> [localities_check]>Paleo Localities<br> <input
> type="checkbox" name="layer" value="geology"
> [geology_check]>Geology<br> <input type="checkbox"
> name="layer" value="roads" [roads_check]>Roads<br> <input
> type="checkbox" name="layer" value="hydro"
> [hydro_check]>Hydrology<br> <input type="checkbox"
> name="layer" value="quads" [quads_check]>24K Quad Index<br>
> <input type="checkbox" name="layer" value="drg"
> [drg_check]>Topo Sheets<br> <input type="checkbox"
> name="layer" value="landsat" [landsat_check]>Landsat<br>
> <input type="hidden" name="imgxy" value="[center]"> <input
> type="hidden" name="savequery" value="true"> <br> <input
> type="radio" name="mode" value="browse" checked>Browse<br>
> <input type="radio" name="mode" value="query">Query<br> <br>
> <select name="zoom"> <option value="4" [zoom_4_select]>Zoom
> in 4x</option> <option value="3" [zoom_3_select]>Zoom in
> 3x</option> <option value="2" [zoom_2_select]>Zoom in
> 2x</option> <option value="1"
> [zoom_1_select]>Recenter</option> <option value="-2"
> [zoom_-2_select]>Zoom out 2x</option> <option value="-3"
> [zoom_-3_select]>Zoom out 3x</option> <option value="-4"
> [zoom_-4_select]>Zoom out 4x</option> </select> <br><br>
> <input type="submit" name="submit" value="Refresh"> <br><br>
> <center><a href="/sdnhmpaleo/default.htm">Back to Project
> Homepage</a></center> </td> <td> <input type="image"
> name="img" src="[img]" width=800 height=600 border=1>
> </td></tr> </table> </form> </body> -----End HTML Template-----
