WMS client and reprojections
    Bart van den Eijnden
    BEN at SYNCERA-ITSOLUTIONS.NL
    Mon Apr 18 00:14:37 PDT 2005
Nuno,
this is possible, and is actually done the way you described.
Make sure that for the METADATA of your LAYER you include both SRS-s (wms_srs), otherwise you get the exception you mentioned.
Best regards,
Bart
Syncera-ITSolutions
Postbus 270
2600 AG  DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> Nuno Gil <nunoragil at GMAIL.COM> 04/18/05 03:48am >>>
Dear listers,
I am trying to use a cascaded dataset available in a specific
projection (lets say projection A).
The server that is serving that dataset is unable of reprojecting data
on -the-fly and I need that data in projection B to be server through
MapServer. Is it possible for Mapserver to reproject cascaded layers?
How can I do this? I have already tried to specify the original
projection (A) in the map file (inside the layers definition) and
requesting the data in my output coordinate system (B) but I receive
an exception saying that the SRS is not supported.
Regards,
Nuno
More information about the MapServer-users
