a problem in make
Frank Warmerdam
fwarmerdam at GMAIL.COM
Mon Apr 18 10:11:50 EDT 2005
On 4/18/05, orkun <temiz at deprem.gov.tr> wrote:
> hello
> in make:
> /usr/local/gdal-1.2.6/libgdal.la: file not recognized: File format not
> recognized
> collect2: ld returned 1 exit status
> make: *** [shp2img] Error 1
> what can I do to solve this problem
Ahmet,
It would appear the libtool library is being picked up for some reason.
I would be interested to see what your "gdal-config --libs" returns.
In the meantime, you can likely hand edit your Makefile for MapServer
and change the GDAL_LIB= line to read:
GDAL_LIB=-L/usr/local/lib -lgdal
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
