Symbols within an area
James Sohr
jms4 at PO.CWRU.EDU
Mon Apr 18 08:17:50 PDT 2005
Well, as far as I know it's not possible directly within MapServer.
You have three options:
1) Generate a large raster image with randomly placed trees, and use this
as your symbol. This is what MSN Maps use, and it's rather easy to
implement in MapServer. Here's a sample using MapServer:
http://img95.echo.cx/img95/4484/a14mm.gif
2) Use MapScript to randomly select a bunch of points. Then, check each
point to see if it is withing a woodlands shape. If so, use MapScript to
draw your tree symbol there.
3) Similar to the solution above, but doesn't need MapScript. Choose a
bunch of random points , and draw your tree symbols there using a new
layer. These points can even be the same from map to map, so you can
hardcode these values into a new shapefile or right into your map file.
Finally, overlay this with a layer that only fills in color where your
woodlands AREN'T-- in other words, you'll need a shapefile that can
identify areas that are not woodlands.
More information about the MapServer-users
