SWF OUTPUT_MOVIE=SINGLE resolution?
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Wed Apr 20 15:38:02 EDT 2005
If you could provide a sample test data and map file with the problem I
can look at it. Or even better you could create a bug and attach the
data to that bug.
I have tried the fuctionnality with my sample data using mapserver 4.4.2
(and also the cvs version) but I could not reproduce the error.
Later,
Chris Hackel wrote:
> No.. there's no labels in that layer.
> Just to test, I changed the mapfile below to:
> LAYER
> NAME Complete_Chain
> TYPE LINE
> STATUS DEFAULT
> CONNECTIONTYPE OGR
> CONNECTION
> "/Library/WebServer/Documents/tigertest/tgr36061"
> CLASS
> COLOR 153 102 0
> LABEL
> TYPE TRUETYPE
> FONT arial-bold
> END
> END
> END # Layer
> and it still doesn't work.
> Any ideas?
> Thanks,
> Chris
> --- Yewondwossen Assefa <assefa at DMSOLUTIONS.CA> wrote:
>>Chris,
>> Is this a problem with layers containing labels ?
>>Can you disable
>>layers with labels and try it again with
>>OUTPUT_MOVIE=SINGLE ?
>>Basically if you want to use OUTPUT_MOVIE=SINGLE,
>>you need to use true
>>type fonts instead of FDB fonts as explained in the
>>post.
>>Later,
>>Chris Hackel wrote:
>>>Outputting SWF, when I set OUTPUT_MOVIE=SINGLE I
>>get
>>>an empty movie. When it's MULTIPLE it works fine.
>>This
>>>problem was described here:
> http://lists.gis.umn.edu/pipermail/mapserver-dev/2004-June/001112.html
>>>but I could not find any sort of resolution. I'm
>>using
>>>mapserver 4.4.2.
>>>Any assistance would be much appreciated!
>>>Thank you,
>>>Chris
>>>Full file:
>>>MAP
>>> EXTENT -74.047185 40.679548 -73.907005
>>40.882078
>>> SIZE 400 300
>>> PROJECTION
>>> "init=epsg:4269"
>>> END
>>> WEB
>>> TEMPLATE "tigermap.html"
>>> IMAGEPATH
>>>"/Library/WebServer/Documents/tigertest/tmp/"
>>> IMAGEURL "/tigertest/tmp/"
>>> END
>>> OUTPUTFORMAT
>>> NAME swf
>>> DRIVER "SWF"
>>> MIMETYPE
>>"application/x-shockwave-flash"
>>> EXTENSION "swf"
>>> IMAGEMODE PC256
>>> FORMATOPTION "OUTPUT_MOVIE=SINGLE"
>>> END
>>> IMAGETYPE swf
>>> LAYER
>>> NAME Complete_Chain
>>> TYPE LINE
>>> STATUS DEFAULT
>>> CONNECTIONTYPE OGR
>>> CONNECTION
>>> CLASS
>>> COLOR 153 102 0
>>> END
>>> END # Layer
>>>END
>>Assefa Yewondwossen
>>Software Analyst
>>Email: assefa at dmsolutions.ca
>>http://www.dmsolutions.ca/
>>Phone: (613) 565-5056 (ext 14)
>>Fax: (613) 565-0925
Assefa Yewondwossen
Software Analyst
Fax: (613) 565-0925
