Mapserver for Windows 2003 + FCGI + SDE
Mark Leslie
mark at REFRACTIONS.NET
Thu Apr 21 14:48:54 EDT 2005
I'm making WMS requests. In order to speed the failure, I'm currently
requesting an SDE layer that mapserver can't connect to (required VPN
connection isn't established) but the fault happens eventually if it can
connect. I'm using jmeter to make the requests and save out the
responses. Each error response contains two new messages, one from
msSDELayerOpen, and one from msDrawMap. I'll have to take a closer look
to make sure my contrived testing isn't the cause, but I recall having
this problem under normal use as well.
Mark
Frank Warmerdam wrote:
>On 4/21/05, Mark Leslie <mark at refractions.net> wrote:
>>Frank,
>>I've managed to clear some of the errors I'm having, thanks to your
>>advice, but I'm still getting a fault in the libfcgi.dll. I am using
>>mapserv.c v1.141.2.2, which sports calls to msResetErrorList, but I'm
>>still getting the a persistant error stack, which I would guess could be
>>the cause of my fault. Do you have any ideas as to why this is still
>>happening?
>Mark,
>Is the persisent error messages occuring with WMS requests?
>There is no error clearing after non-OWS requests, and some
>very early errors could also pile up on the error stack.
>Can you provide details on what is happening to you?
>Best regards,
