quering layer using result of the query on another layer
using php mapscript
Camden Daily
cdaily at GMAIL.COM
Fri Apr 22 10:20:09 EDT 2005
I can't see why not. Once you have your first set of results, just
loop through them and perform a query on each of the result shapes.
Are you trying to query points both times? If you can be a bit more
specific, I can help you out.
-Camden
On 4/21/05, Arunoday Chatterjee <arunoday_chatterjee at rediffmail.com> wrote:
> Can i use the query result from one layer to query another layer.
> Basically to display only those data from the other layer that is relevant
> with the first layer that is queried on.
> Can anyone help on this.
> I'm using php mapscript 4.2.3.
