Drawing TIGER file Polygons
Frank Warmerdam
fwarmerdam at GMAIL.COM
Fri Apr 22 12:19:58 EDT 2005
On 4/22/05, Chris Hackel <cvhackel at yahoo.com> wrote:
> How does one extract polygon data from TIGER files in
> a directory? I can't find any good documentation and
> the only reference I have is the snippet below.
> I understand the script for the most part, but this is
> coming from a database, whereas I just have a
> directory with the RT1, RT2, RT3.. etc files in it.
Chris,
The GDAL source distribution includes a tigerpoly.py script
that will form polygons from tiger data. Basically the issue with
TIGER data via OGR is that OGR gives a very literal view of the
tiger data and you need to form the polygons yourself.
http://www.gdal.org/srctree/pymod/samples/tigerpoly.py
I understand Schyuler (author of Mapping Hacks: http://mappinghacks.com)
has also written a similar script that loads the data into PostGIS and
does some additinoal transformations on it.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
