quering layer using result of the query on another layer using php mapscript
Arunoday Chatterjee arunoday_chatterjee at REDIFFMAIL.COM
Fri Apr 22 15:16:33 PDT 2005
Basically i'm displaying the county and city data in the first shot and i
want to display streets data as the map is zoomed out. Since the streets
data is huge, it is failing to load hence i need to filter the streets
data. So i was looking for a solution to fetch and display only street
data relevant for the visible region of the map.
Can you pls. let me know how to achieve this?
Also, i have a dropdown of city with the FIP as the value and i want the
map to move to the city location based on user choice. How do i achieve
this?
Do i use filter or expression, as i'm already using an expression
as '[TYPE]' eq 'city' but when i change it to say '[PL_FIP]' eq '00884'
nothing comes up, why is it so?
Just wanted to let you know that i'm generating the map by querying a
dynamic layer with some location content.
Any direction would be very helpful, as there are no advanced php
mapscript example.
More information about the MapServer-users mailing list
