Perl Mapscript "issues"
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Sat Apr 23 22:13:45 EDT 2005
Also check that you do not have an old libmap.a hanging around
somewhere. Delete if you do. You might need rebuild stuff if you did and
removing it does not resolve things.
-Steve
Sean Gillies wrote:
> On Apr 23, 2005, at 6:44 PM, Nick Floersch wrote:
>> Hi All,
>> I recently posted a long bit about my problems getting a newer version
>> of Perl mapscript to work with a perl mapscript app we have here.
>> The question has changed.
>> NOW, I need to know this:
>> Why, when I try to instantiate a map object with any map file other
>> than
>> "" do I get a segfault?
>> v---snip---
>> #!/usr/bin/perl -w
>> use mapscript;
>> use XBase;
>> my $mapObjFull =3D new mapscript::mapObj("itasca.map");
>> warn "Got Here 2.5";
>> ^---snip---
>> This gives me a segfault.
>> The itasca.map file is the one found in the mapserver demo "workshop."
>> If I call new mapscript::mapObj with no map, it works fine:
>> v---snip---
>> #!/usr/bin/perl -w
>> use mapscript;
>> use XBase;
>> my $mapObjFull =3D new mapscript::mapObj();
>> ^---snip---
>> Will produce the message "Got Here 2.5 at line 6" or something like
>> that. It works fine.
>> Just to rule out the idea that itasca.map had a layer or something that
>> it couldn't access (though it works fine in the workshop demo), I made
>> a
>> copy of it and commented out ALL layers.
>> It still segfaults.
>> In desperation I used the helloworld map from the tutorials thinking I
>> could avoid any issues with non-existent data layers etc.
>> It still segfaults.
>> Someone mentioned looking for libmap.a and see if it is an old version.
>> I don't have libmap.a in any library path. Yet, the old files for perl
>> mapscript work perfectly. It's the new ones that don't.
>> What am I missing here? It isn't the map files. It's something about
>> the
>> perl mapscript build.
>> I am trying to do all of this with Mapserver 4.4.1 or 4.4.2. Neither
>> version has worked right yet (with mapscript at least - everything else
>> works fine).
>> -Nick
> Nick,
> Are you certain that you are using your newest mapscript module? Try
> printing the value of $mapscript::MS_VERSION before you make a new
> mapObj instance. You should get '4.4.1' or .2.
> cheers,
> Sean
> Sean Gillies
> sgillies at frii dot com
> http://users.frii.com/sgillies
